NaiveSound
- Nov 8, 2015
Hi
Did anyone answer the question "which is the best cable for the !2t"?
Many thanks
Lol.... *Best*....
Hi
Many thanks
I’m using the Alo ref 8 and I think it compliments the A12t very nicely. Definitely content for the foreseeable future with this combo
I use the same. Do you use M15 or M20?
Can anyone comment on how the U4 SE do with classic and prog rock? Very interested in these and I've narrowed my choices down to the U4 SE and Earsonics E3. There's a pair of U4 SE that caught my eye and I like the idea of the APEX module to regulate ear pressure. I've read everything I could about these, including Twistr's review and even the comments on the discussion thread of Massdrop, and I don't have a clue how these would perform with rock music.
Thanks. Exactly what I needed to hear.It's one of those all-rounder IEMs that perform great with any genre. Very rare to come by since they have been discontinued for awhile now, and even when they were for sale on MassDrop, it was one crazy value.
Anyone using aftermarket cables and actually uses the 64audio case? Any side effects of coiling your cables in that case?
I’m using Leonidas and lion heart. It fits, just worried the cable might be damage in the long term.It all depends on the cable. Some thicker gauge multi-braid cables might not fit, especially with 4.4mm plug, and some have a thicker and/or tighter wire shielding/jacket that can cause a memory effect (a wire coil that hard to straighten). I think those cases are intended more for traveling musicians who use a stock cable, to keep everything secure and dry inside.
I have the Ref 8 also but it's such a microphonic cable.. does it bother you guys as well? I've been thinking of trying other less microphonic cables despite how good the Ref 8 sounds..
Just got my A18t! My order only took a little over 4 weeks to get to Taiwan, great job 64 Audio!
This is my first custom IEM and I'm really impressed with the fit, just wow. I did a relaxed-jaw, closed-mouth impression and the fit is perfect: no tightness, no looseness, and no discomfort moving my mouth/jaw around.
Time to enjoy some music!
Yes, the faceplate color is translucent black.Those look great!
What faceplate color is that? Translucent Black?
