1960 2- and 4-wire have different characters (resp. 4 and 8 core cables due to their coaxial design). To me, 2-wire has a warmer, more organic signature, while 4-wire has a lift in the upper treble, besides greater extension. This improves its resolution and transparency, but also gives it a brighter touch on top, which can ocassionally be too much depending on the pairing/listener.
However, the K solder that MS uses tends to smooth the treble, while it can improve resolution. Even so, it does not give it a warmer sound. Another example was the Eos cable, which was an Ares II with the same K solder and a Furutech plug. Compared to Ares II, it has a more neutral tonality with improved resolution. I also had a plusSound GPC cable reterminated with that solder and plug, so I have gotten a sense for its general characteristic. With the K solder, the 4-wire's upper treble trades some of its sparkle in favor of a smoother sound.
