ceeloChamp
Oh I'm an idiot you are using that with the U18ts aren't you?
Goodness, that's decadent. What are you pairing that with?
I expect that @Giraku will, but I don't have it myself. Just a little too decadent for me right now, as it's a $1,599 cable (hence the luxurious box). It did sound pretty darn good when I demoed it with the U6 though.Oh I'm an idiot you are using that with the U18ts aren't you?
Thank you Giraku, I will definitely give them a try.You have a similar taste as mine. Try Emilie-Claire Barlow, Bria Skonberg, Lyn Stanley, and Your Sun Nah.
I'm using the Horus with my U18t now. I will experiment with Fourte soon.Goodness, that's decadent. What are you pairing that with?
Oh, that's gonna be a very expensive case.Man, I'd almost buy the cable just for the case!!
Thank you. How do you find they compare to the 08?
I looked into your recommendations and they are all good. Thank you @Giraku I think you might Lisa Lovbrand, she did an outstanding cover of Light My Fire.You have a similar taste as mine. Try Emilie-Claire Barlow, Bria Skonberg, Lyn Stanley, and Your Sun Nah.
Also thank you @felixaaron
Any recommendations on 4.4 balance cable?
It does. But the magnitude of the quality deterioration is not big. To my ears, difference in cables has 98% of sound signature influence.Do adapters effect sound quality? I always feel like it will when I connect a really nice cable to a mediocre adapter.
Thank you @Giraku i also just went to 64Audio site and see that they also have a cable available to order with terminated to 4.4.Wow, she is good. Thank you!!
For 4.4mm plug, I use 4.4 -> 2.5mm converters as I have multiple cables terminated with 2.5mm plugs.
