Mine sits in okay at the initial insert and I do not feel sound leaking either but after a while I feel it's not sitting in tightly.
sometime feeling air pop with certain head movement. Sound wise I think it's not detrimental and in fact, it sounds same
as right piece having good fit. I just don't feel comfortable as right ear piece don't appear sit in tightly on the ear canal area.
Not exactly sure it may be positioning issue.
If you only have an issue with the tip they will most likely trim it short. So may be okay but then they were supposed to do the very
minor adjustment in the beginning for me. I am hoping I get use to this feeling air pop but if not, I will just crack it and walk away..
