PixelSquish
Previously known as idiotekniques
- Jul 13, 2005
ahh yes. my memory failed me. thanks for the correction.that is the orange one as I remember, and 64 Audio does not recommend using this module with IEMs.
What was the cable that you prefer with the Volur? i'm using a pure silver cable from lavricables Grand Line and love it!
Pure silver works well. Also like Eletech Raphael with it. I find Volur more ear tip picky than cable picky.What was the cable that you prefer with the Volur? i'm using a pure silver cable from lavricables Grand Line and love it!
Yeah well. I guess that's LID at work.....Pure silver works well. Also like Eletech Raphael with it. I find Volur more ear tip picky than cable picky.
Thanks for the kind words There are a few I liked with Volur, including Eletech Baroque, Acoustune AEX70 and AEX07, Sedna Crystal, and JVC Spiral Dots. Really depends on fit and comfort, and which part of the FR you want to emphasize. Any tips that give a good seal for the bass to do its work would be my rec.Your review was incredibly detailed and well written. I just resonate with your input more than other reviewers and I get a better sense of the sound as it relates to my preferences. I would argue that the combination of your review layout, content, relevant comparisons, and photos, you are among the best there is. I genuinely get excited when you review a product I am interested in. I don’t say that lightly. Despite what others have negatively said about reviewers, the community as a whole appreciates all that you do and the effort that goes into your work.
I do have one question though: what are your preferred tips for the Volür?
For what it's worth, I'm using Sedna Earfits, but these are my go-to tips for most IEMs. They work very well for me with the Volur.Thanks for the kind words There are a few I liked with Volur, including Eletech Baroque, Acoustune AEX70 and AEX07, Sedna Crystal, and JVC Spiral Dots. Really depends on fit and comfort, and which part of the FR you want to emphasize. Any tips that give a good seal for the bass to do its work would be my rec.
Thanks! i'm curious to try the Effect audio fusion on the Volur, still think silver can work best.For what it's worth, I'm using Sedna Earfits, but these are my go-to tips for most IEMs. They work very well for me with the Volur.
@Francisco Evangelista I have used two cables with the Volur - a pure silver (type 6 litz), and the Mini Chimera from DHC. I just received the mini chimera yesterday and am still getting to know it, but so far it's a stunner with the Volur.
@Damz87 could, if he has the time.Hi everyone,
Is someone has been able to compare Fourté Blanc and Fourté Noir ?
Thx,
MG
I am also constanltly wowed by the bass on volur. Its not just excellently just right in quantity but also the cleanliness and quality to it.The amazing thing about the Volur is the quality and quantity of the bass, and it just never really bleeds or messes with any of the lower mids.
Are those ear tips Symbio F?The full luxury portable setup when I want it all with me. It's actually a pretty small profile case.
Volur, Eros S cable with Con-X and Termin-X features. iFi Go Blu, all the modules, cleaning tool, plus a usb dongle in case I run out of battery. In the little black box is the smaller balanced plug and the 3.5mm plug so I can always switch them out if I bring the Qudelix 5K out with me or use the dongle. Also in there are a set of the MMCX Con-X connectors, so I can just throw in a different pair of IEM's and don't need another set of cables with them. I can just change the connection on the Eros-S and keep going.
