The New HIBY R3 II is here. 4.4MM Jack; Improved Sound and Bluetooth.
- Thread starter CactusPete23
Kyle P
Wondering how the 2022 version stacks with Shanling M3X.. just sucks that this has a 2.5mm balanced rather than 4.4mm.
Very close to order the new 2022 version, just unsure if I wanna step up and get an android device. Can always send it over with Bluetooth from the mobile if I don't have something I wanna listen too. Does Hiby usually have sales during autumn or blackfriday?
you could wait for December for the Shanling M1s. It is also a non-Android M-Touch device. It will have a 4.4mm, and will use the more advanced Ingenic X2000 CPU rather than the X1000E that the Hiby uses. Plus it will have better DAC with the ESS ES9038Q2M. Shanling hasn't announced the price or battery life yet.Wondering how the 2022 version stacks with Shanling M3X.. just sucks that this has a 2.5mm balanced rather than 4.4mm.
Kyle P
Can't seem to find a comparison with these ESS chips, is the ES9038Q2M chip better than having dual ES9219 chips? (and by extension, the M3X's Dual ES9219C chips as well?)you could wait for December for the Shanling M1s. It is also a non-Android M-Touch device. It will have a 4.4mm, and will use the more advanced Ingenic X2000 CPU rather than the X1000E that the Hiby uses. Plus it will have better DAC with the ESS ES9038Q2M. Shanling hasn't announced the price or battery life yet.
Jmop
- Sep 17, 2014
I'd go for the new R3 if I didn't just get the original Saber. It's either that or maybe try the M1s for balanced with IEMs. M3X is kinda overkill I think. Or try Hidizs.
InvisibleInk
Here's a weird problem for our shared experiences. My R3 Pro is now stuck such that I can only use the balanced 2.5mm port for listening. I've tried to connect multiple 3.5mm cables, but the port never switches to single-ended, remaining stuck on balanced.
CactusPete23
One way this can happen if the 2.5mm jack gets "stuck/shorted" so that the DAP thinks there is a Jack in it. It could be dirty, or just stuck. With the unit off, try cleaning the 2.5mm Female jack on the R3 with some 90% Isopropyl Alcohol on a piece of "Pipe Cleaner". (or just try inserting and removing a 2.5mm jack several times.) Let it dry out, and see if the 3.5mm now works.Here's a weird problem for our shared experiences. My R3 Pro is now stuck such that I can only use the balanced 2.5mm port for listening. I've tried to connect multiple 3.5mm cables, but the port never switches to single-ended, remaining stuck on balanced.
InvisibleInk
Thanks, I'm giving your suggestions a tryOne way this can happen if the 2.5mm jack gets "stuck/shorted" so that the DAP thinks there is a Jack in it. It could be dirty, or just stuck. With the unit off, try cleaning the 2.5mm Female jack on the R3 with some 90% Isopropyl Alcohol on a piece of "Pipe Cleaner". (or just try inserting and removing a 2.5mm jack several times.) Let it dry out, and see if the 3.5mm now works.
Has anyone use R3 pro sabre 2022 with mojo 2? Do you notice any RFi while streaming?
Jmop
- Sep 17, 2014
I might be putting my OG Saber up for grabs soon if anyone’s interested. Haven’t had any issues, but I don’t stream or use Bluetooth so no comment on how it fairs with those. Great device, but it doesn’t really wow me.
Oscarilbo
- Nov 6, 2012
Hi guys. Merry Christmas…
I’m thinking on getting the Pro or the Pro Saber. I want to use the HibyR3 only as a transport to my external Schiit DAC. If I do this, will the volume be controlled by the R3 or by the amp that is connected to the external Schiit DAC?
dafos58
It will be controlled by the external DAC.Hi guys. Merry Christmas…
Oscarilbo
- Nov 6, 2012
What USB-C to Micro USB could you recommend for connecting it to my Schiit Modi3+ DAC? I’ve read somewhere that an OGT cable is better for something like this, or at least has worked for some folks (although I think on those cases they were using android phones) . Whats the difference?
CactusPete23
ANY USB Type C cable to Micro USB should work. (As long the cable is not "charging only"; Or missing data connections.) Just make sure it has DATA and Charge connections.What USB-C to Micro USB could you recommend for connecting it to my Schiit Modi3+ DAC? I’ve read somewhere that an OGT cable is better for something like this, or at least has worked for some folks (although I think on those cases they were using android phones) . Whats the difference?
(Actually don't need the charge connections with a powered DAC, but for a "dongle" or unpowered USB DAC the phone provides the power for the DAC to operate.)
The Older Micro USB connector on the phones needed a special cable to make the phone act as the host. (The OTG "On The GO" Cable moved a ground cable to a diffecent connector point)
The USB-C cables will work, as long as the phone has OTG function, and that function is turned on.
