smithamb
- May 15, 2014
Just tried to order the fx850 from digital rev and they cancelled my order due to JVC discontinuing the item...
Is this true?!
Is this true?!
Say... Why does it seem like everyone on this forum seem so against EQing? I just don't understand... You are literally few clicks from turning FX850 from unimpressive to DAFUQ DIS IEM IS DA BEST... I understood why the HP folks don't EQ much because, I dunno, full sized cans never sounded quite right when EQed. However, the FX850 just sounds so natural when EQed as if it was their original sound. The frequency curve of the FX850 is extremely easy to EQ to flat response too!
I think we've had this discussion before.Can't speak for everyone, but here are my reasons:
First of all, I'm not opposed to EQ at all. However, ...
- ... many DAPs have poor EQ implementation, so you'll need something like Rockbox, or an IOS / Android based source for really high quality EQ.
- ... if you're using your IEMs with several DAPs and / or a stationary source, getting the same EQ on all of them can be a pita.
- ... modding will change the signature consistently and once-for-all, no matter what source you use.
- ... modding can achieve more than EQ, e.g change transients or equalize air pressure.
On the other hand, some issues like e.g. treble spikes are much easier to correct with EQ than modding.
Bottom line, I think the most important thing is to stay open-minded und simply try out what works best for you.
Well I am not against EQ but if it could make the fx850 sounds much preferable and can tame the wild bass~why not? Mind to share your EQ settings you used for your Fx850? Might as well trying it out for myself
yes I find front mod does a big differences, I feel without this mod FX850 just throws all part of music to your ears IMO, bass is quite boomy and finer notes of music is also brought front. With mod, FX850 bass is tamed and imaging is better, there is more space between each instrument. But is not a day and night difference IMO, it does tune FX850 for better.
Someone here said that you can change product price on the package if you use tenso.
Can someone please confirm this.Maybe someone who has used this service before ?
I used tenso sending the jvc 850s and a packet jvc eartips. They sent me 2 different packages and charged me for the 2 packages individually. they marked the full price on the earphones, so now im paying the full import/handling. I don't recall an option where you could choose your own value. This was my first time using Tenso, maybe I missed that, or you have to personally ask them?
thanks james, now I have to post something right?
I think we've had this discussion before. Can't speak for everyone, but here are my reasons:
Apparently, you can change impulse response via DSP, but I don't know if it can be done just via EQ or what it takes. The reading was a little over my head.
This DSP component takes impulse response and does a
fast convolution of the sound data with that impulse
response.
Basically, it allows quick computation of any combination of
linear effects, such as equalization, echo, flange, reverb,
phase shift and so on. It can transform the sound to exactly
the image you would get as where the impulse response was
recorded, allowing you to get an accurate reproduction of
a big theather or stadium.
