kahaluu
I've been using some TF10 tips. I like them because they tone the bass down a bit.
Hi guys,
Reading about all the goodnessabout these IEM's I decided to take a plunge. I'm torn between FX750 and 850 though. Funds are secondary consideration, but the form factor is. Currently I'm using Klipsch X-10. These are really small, light and comfortable to use, but have tendency to slip out when on the move. I'm not talking jogging or such, just doing some chores around the backyard. Also the cable cable on these is very microphonic.
I assume that the drivers are identical and so can anyone in here say that 750 and 850 sound the same, or is there a difference in sound because 850 has larger enclosure? Looking at the side by side pics it seems like the increase in size was dictated by fitting the connector, but is the internal chamber bigger as well, giving the 850's the sound people here rave about?
I have both and enjoy them each for different reasons. I will say this if you listen to the dn1000 in low noise low volume they sound amazing! I'm still surprised. I use both with with my Sony f887 and e12. On the go or at work I use my 850's. When I'm home and need a bit more I isolation while significant other sleeps 1000s, I listen and feel like I'm falling/floating in the music pretty cool. And the clarity is superb. I love bothAnyone has both the DN-1000 and the FX850?
How do you think they compare? I just got my FX850 and had a short listen, probably only 20 mins. I think they are quite similar. However, I do think the soundstage of the 850 is much wider and the clarity is better. Instruments sound more realistic and mids are more forward. I don't know how to describe the bass and treble tho. Maybe I will have to spend more time with it. Listening to music with lots of focus on instruments are definitely very enjoyable. Definitely a step up. What do you guys think?
Then my Clip+ plays Daft Punk's Derezzed....dat bass..now I understand.
I don't wanna take them off..
50-hour mark impressions:
The burn-in change is interesting for me. At this point of time the thick bass actually subsided for stock tips while not on the Ortofon tips. With this I would actually DQ out the Ortofon tips much to my surprise.
And thanks to @ericp10's recommendation for the cheap Fiio RC-SE1 SPC Cables, I managed to grab one out of curiousity and they do scale well with the DX90, bass is more tight while the mids gets a lil more refined. FX850 actually performed well for male vocals over female vocals which I found to be opposite for FX700 on an Ortofon tips, but with that said I am not missing the sounds of FX700 at all.
(P.S Although fiio cable does make the FX850 a lil too bright on inferior sources such as my Samsung Galaxy Note 10.1 2014 Edition)
I swapped the Left and Right connectors and used them over-ear with adequate comfort and all is well.
Although I am just curious here, did anyone else faced the problem where other MMCX connectors cannot connect to the FX850 (which has quite a deep socket)
My first pair of Fiio Cables had connection problem on the left side where it just cannot enter the FX850 socket. Fortunately second pair after an exchange on-the-spot works fine.
I am worried that the 93spec cable will have this issue also. Keeping my fingers crossed that they will fit when it comes..
Ordered a silver cable right after I bought e fx850 cos its a bit too warmth for me....but now after 4 weeks of usage w a double flange, am loving e sound more n more each day n dun feel like I need e silver anymore. Cant wait to see how much better it can get w e cable. Still cant use then w complys which I find most comfortable as e bass gets too kuch w them n e highs too recessed.
