Koei
- Mar 11, 2009
So this uses normal SD cards (SDHC etc)? Good, I'm drowning in them (due to my camera
). Can we have an estimate on the price?
I believe its MicroSD card.
Ah, balls. But anyways, still want this. What is the reason to go for the smaller cards? No room for normal SD? Isn't normal SD memory cheaper/gb?
Probably just easier with a smaller size.
They aren't easier to change or keep track of. Not unless you have a retinue of pixie assistants or something.
Was really looking forward to this player but its going to put my E7 out of comission
hmmm
will have to check the price of it closer to release date, would be great to have an all in one player/amp though
I'm a little sad about this too. Buy an E9 and just leave it in there
Then lug around your X3.That's my plan
or combo'd it with the e11![]()
...Which isn't out either.
Get on it FiiO.
I have read there are compatibility issues expected for sizes greater than 32GB and I want to be sure I will have the option to move upward towards the theoretical maximum capacity of 2 TB (Obviously I am more realistically concerned with 64GB and 128GB)?
2 things. You are largely referring to sdxc which would need to have firmware updated to allow the use of gen 1 sdxc cards. About a week ago someone, I think Lexar, released a 64gb and 128gb sdxc card but not micro sdhc. In theory it should be supported if the X3 is allowed to support it. Same will be true for all gen 1 sdxc cards. Here's the rub. Next gen sdxc cards, which are right around the corner, will add another pin to increase transfer rates. When that happens the X3 will not be able to support those gen 2 cards.
