davidcotton
X-CANs and HDAMs
- Jun 23, 2001
It's a shrunken X5, or a grown up x1!
The CS4398 isn't particularly expensive, being used in Creative's SBZ, which can be found on ebay for $50. I don't care that it's being used in the X3 II as it's not a particularly expensive DAP (relatively speaking, of course). What I don't get is why it's used in the AK100II/AK120II/AK240. There are better DACs that can be used, indicated how how Creative uses the PCM1798 DAC for its flagship SBZXR instead of the CS4398 on the much cheaper SBZ.
I do like the design the X3 II uses.Looks a bit like a rejected X1 design(?).Looks close enough to the X1 design that I probably won't be able to tell the two apart if I don't have them both to compare.
Here is a bit on the new X3. Very nice looking DAP!
- Native DSD Playback Support
- In-Line Remote Support
- 10 Band EQ
- Custom Playlists
- All New Exterior Design w/Full Metal Body
- Classic Scroll Wheel Control
- Dual Crystal Oscillators for Less Jitter
- Deep Sleep Mode for Instant-On Usage without Battery Drain
http://blog.sonicelectronix.com/home-and-portable-electronics/fiio-releases-ces-2015/#prettyPhoto
Does it have bass & treble hardware adjustments ?
It has an EQ which should be good enough for tailoring bass and treble to your liking. I'm guessing that it doesn't have a treble/bass gain switch due to the fact that the X5 and the X1 don't either. If you want that, you'll have to get one of Fiio's mobile amps/DACs.
okay ... it still so tempting by itsrice -size, look and build quality - inline remote support - the new dac and reduced jitter and finally the 10 band eq BUT ONLY IF IMPLEMENTED WELL because the 5 band eq in my X3 almost useless for now ....
so while i may consider getting one .. but i will never let my original X3 go away and keeping it for its wolfson dac and its warm lovely sig. and the bass& treble controls which cant be found in a player these days it still a unique one
No way I'm getting rid of my X3 for an updated model with that friggin mickey mouse dodgy bloody scroll wheel. Not getting rid of my X5 either as it's SQ is awesome with my current IEM. But Jesus Christ, f%$king around with that wheel and watching it misbehave the way it does frustrates the crap out me and makes me want to rage quit and throw it. Watching it go the opposite direction of rotation sometimes is just awesome.:mad:
Had the new X3 not had the wheel, I would have been in like flynn.
If it has been implemented to work as it "should" on the new X3 then I will quite happily eat my words and fork out the dollars for it.
And just to clarify "should" will mean no more jumping forward 3 selections, moving in the opposite direction and sometimes no movement in the menu at all.
Just saying.
Edit: Yes you can use buttons to bypass the wheel controls but you still have to press the centre button on the wheel to select, and when doing this, it sometimes decides to go back or forward and totally screw you up. It's just not good enough. Was not going to bring this topic up again but hell, it is an issue and I sincerely hope they sort it out on the new X however with manufacturing costs the way they are I think it's going to be the same mechanism used on previous players. That to me is a deal breaker. I'm hope I'm wrong.
Don't know about the wheel ..never tried one before but i hope that they fixed these issues in the new productions
