x RELIC x
Joe recently posted on the X5 II thread that If/when the battery needs servicing FiiO sends out a new battery for under $20 along with instructions for those with the proper know how (local shop) to do the job.
Thanks for the info!
Would be nice if Fiio could post the instruction here, as there are some hardware geeks in this forum![]()
Hopefully the battery will still be available in the next 2-3 years. The battery connector of X3ii seems to be removable, hopefully no soldering required.
I'm pretty sure it's a good policy NOT to post the instructions here. Imagine all the warranty claims that would ensue from less than capable hands and weekend tinkerers.![]()
I have the Grado GR10's and X3ii and E12, the sound is stunning. Clear, and detailed. A little mid-prominent but one's brain compensates quite quickly and the sound quality is very inviting and addictive.
Googled. About $750. Gonna pass it.![]()
Some iem-s are out of my reach, some are not easilly available.
I assume I might get etymotic hf5. How do they go with x3 II,
for neutral, 24/192 sound?
BTW, this se210 look better and better. Or I became music proof.
Still good opinions on superlux hd381F ?
Best regards all.
Do you mean from X5 onwards, all Fiio players support 32 bit floating point files? Do they support most common format of 32 bit files? Wow, I didn't know this![]()
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
All X players up to and including the original X3 now have the 32bit mp3 decoding described![]()
They also unofficially support higher res WAVs, up to 64bits. Which of such files are supported, on which players, is up to you guys to play with and check out![]()
Someone brave enough to make a MicroSD-card slot in the Dignis case?![]()
Still love it, top notch case.
Where can i get this Dignis case? A tried to find it but no luck. I like the function signs on that case.
Btw, what about usb cable? I'm a bit skeptical about better usb cable improving the SQ, but ready to test it. So what do you think/experienced, how is a 30€ usb cable (like Audioquest Pearl or what you suggest) compared to the stock one?
I'm really starting to warm to X3II, especially with Fidue A83 these past few days. I can definitely hear what the hype is about.
Good pairing?
Definitely. I'm working out X3II avoids that often pronounced push in the upper mids some players have.
Instead offering a thick amount of detail evenly across the frequency range. It can take a little adjusting coming from the iBasso DX50 if you've been using one a while. Though easily detectable X3II has better layering and separation. Once you understand the detail is staying tightly in place rather than jump out at you (ie upper mid push) its a very good player. A83 sits well as it removes some of the aggression presenting a more balanced amount of detail.
its a very musical player X3II, quite involving. I really like it.
