The FiiO X1 Discussion and Help and Support Thread |192K/24B|100mW | LO | inline remote
May 6, 2015 at 10:43 PM Post #5,656 of 7,793
just google how to format a sd card to fat32. it's not a new  or unique question and you'll have plenty of tutorials for all kind of computers with all kind of OS. there is no trap, it's not difficult and worst case scenario, if it doesn't work, you try again. so don't worry about it. :wink_face:
Unfortunately for the FiiO DAPs not all format software works well. Recommend using the device to format the card as it works 100%. More than likely it's allocation unit size that causes issues. Just read the first 200 pages of the X3 Classic thread or the X5 thread and most of the issues with cards came from not formatting in the device.
May 6, 2015 at 10:53 PM Post #5,657 of 7,793
oh yeah, even easier, I always forget that we can format using the DAP itself.
May 6, 2015 at 11:21 PM Post #5,658 of 7,793
So we could format the card in the player itself and then use it to update the player? After the format in player, do we have to format it again back to NTFS so it could store files?
I'm sorry but I know nothing of the different file formats!
May 6, 2015 at 11:42 PM Post #5,659 of 7,793
Stick card in, format through the settings menu, copy files to device, listen with a smile on your face. If you need to update firmware just load the x1.fw file (after unzipping it) to the root of the card (not in any folders), and update.
No need to remove any music files or delete the firmware file after the update. FAT32 is the prefered format to use and there is no need to use NTFS, or exFAT unless you have a single file over 4gb (not likely).
May 6, 2015 at 11:52 PM Post #5,660 of 7,793
Thanks so much. :cool:
May 6, 2015 at 11:58 PM Post #5,661 of 7,793
:beerchug:
May 7, 2015 at 9:48 AM Post #5,662 of 7,793
According to the official tutorial, one has to use a card formatted to the Fat32 format. I have a 32GB Micro SD card coming in...Sorry for the newbish question but is that card already formatted to the Fat32 format or do I have to format it with the player first?
Thanks.
SD cards need to be formatted in the device that use it.
:cool:
http://www.tomshardware.com/answers/id-1726154/format-64gb-card-exfat-fat32.html
May 7, 2015 at 2:05 PM Post #5,666 of 7,793
  i was wondering how does the iphone 6 plus compare to fiio x1
there you go http://headphoniaks.com/blog/calidad-sonido-smartphones-iphone-6-htc-one-m8-fiio-x1/
May 7, 2015 at 2:41 PM Post #5,667 of 7,793
Is it me or when I try finding my x1 in my bookback and my x1 turns on
May 7, 2015 at 8:35 PM Post #5,668 of 7,793
Is there an option of turning on the screen (while the unit is locked/idle) without constantly pressing the power button? I simply don't want to wear the button out, you see.
Also, what's the difference between favorites & (on-the-go) playlists? How many songs can be saved in a single playlist?
May 7, 2015 at 10:42 PM Post #5,669 of 7,793
+1
I also don't want to press the power button at all.
May 8, 2015 at 6:48 AM Post #5,670 of 7,793
Hi There! I rarely used my X1 due to the issue that I've encountered wherein, after finishing all the songs from an album. I was expecting it'll jump right after the next one. Just like if I copied 1 song from a certain album, in order for the other song to play, I need to do it manually. I really like listening to music especially when Im cleaning the feeding bottles of my daughter, and you know that if the song is already finished from an Album and your hands are wet, it's a waste of time wiping your hands and then unlocking the player and then pressing the play button again.
I've tried using the X1 again and updated the firmware to 1.3 and I've seen new options like Supports in-line headphones thingy and play through folders and I tried turning it on and then play a song in an Album and I was expecting after the song finished it'll jump to the next album. But to my Dismay it's still not playing. Im not sure if Im doing it wrong or the X1 really don't have that option at all. Can anyone give me an advice on this?
