CH23
- Nov 24, 2012
Is that because there is a risk of blowing the IEMs or because they could make you go deaf? I gather IEM is Inner Ear Monitor?
You should always have some form of amplifier between the DAC and your headphomes/earphones.
The signal is called line out, because it's just the direct line out of the dac, with no opamp in the signal path.
You can't regulate the volume, and if you have regular to very sensitive headphones, you might blow them out, or worse, your eardrums.
And indeed, IEMs are In Ear Monitors
