LCMusicLover
Should work fine from 3.5mm SE output for IEMs. In fact, the original P2 probably wasn't 'really balanced' as the output voltage is exactly the same for either output. If you're only going to use the SE output, the only thing you're missing (og vs mk2) is the extra 128Gb internal storage.Plenue 2 Mkii no longer available but I pulled the trigger on the regular Plenue 2. I won't be using the balanced out so I hope that doesn't make a difference at all and I'll be using IEMs only with it. If I don't like it I'll just return it yay
And yes, the mk2 appears to be sold out at the Cowon Amazon store.
