Richsvt
One last song to post, just really digging this sound.
But at that size, how long does the battery last before needing another top-up?On the topic of portable amp, I am doing a demo of Periodic Audio's new tiny Nickel amp. Running it through some set-ups and seeing how it works. Gotta say, for its size (about the size of a 9V battery) it can really punch out the volume.
Here it is strapped to the N5ii and listening to the AQ NightOwls
Here attached to the X3ii and running the TFZ Queen.
I dunno if I can trust that. One minute I'll be listening to some smooth tunes and the next, my rig's going to be sitting on the ears of some dude in the 1980sWhat if it has a small Flux Capacitor power source?
Well, will be getting the MS4 in april... Will keep everyone posted
I ended up getting the MS1 from their campaign - mainly because I wanted all the additional accessories like the USB Cable and Bluetooth cables, so went for the cheaper actual IEM. Been busy reviewing a lot of single DDs, so will be good to see where Hidizs fit into the current sub-$200 landscape. Hoping their cable used the same DAC chip as the Sonata II, as use that with my Pocophone F1 and it sounds excellent.
Got some nice toys arriving / arrived recently a little higher up the food chain, too - currently listening to the AKG N5005 (sub bass monster) and the R1Zenith (very good), and the Dunu DK-4001 should be landing next week. Had a very good few weeks with deals!
Sadly the law of balancing your finances states that two of them will be leaving soon if I want to carry on eating, but looking forward to seeing what the current higher end hybrid market sounds like.
I notice that HiBy doesn't mention how long you can use the W5 between charges.
But, the W5 specs do say:
Internal Battery = 150mAh
Battery Case = 1000mAh
Playing Time (including Case) = 20 hours
So, 1150mAh of charge will last 20 hours.
150 is 13% of 1150, which means that the W5 will play for ~2.6 hours, before going back in the case to charge again.
The Charging Time is listed as ~1.5 hours.
If all those times are accurate, the W5 can be used for ~6 hours during a 9 hour workday (including 1 hr Lunch Break).
My fully charged Radsone ES100 will work pretty much the whole day, without having to recharge - but if needed, it can be used while it's plugged into the USB cable to charge (it's just not portable while charging).
