- Jan 30, 2011
thanks a lot. So this software is to verify the format of the audio files right?
Not to verify format. Its a guide so you can transcode and test containers against one another.
Eg - take a 24/192 file, transcode to 24/96, 16/44.1 and even MP3 or AAC. Test yourself using the blind testing functionality. See if you can tell the difference. Because its from the same master, and you use replay gain to normalise (volume match), and you don't know which is which - you take the test and the software randomises it. Its an eye opener. I thought (years ago) that I could easily tell the diff between high-res and high bit-rate lossy. I can't. Take away your sight and it call comes down to audio.
