majo123
- Jan 1, 2016
Can't help much with amps. Dap has plenty of power for IEMs and it would cost so much to match the DAP's internal amp quality. My long range plan beginning 2016 was to buy a Bottlehead Crack amp kit that winter. It only works with high impedance cans like my adored Sennheiser HD600. Supposed to be heavenly with HD600. The M&J GL2 happened beforehand. Then the MJ2. Thankfully I didn't buy an amp that only works at 300 ohms. Have briefly played the GL2 with dad's Schiit Magni. Sounded good, not necessarily better than hooked directly to the Pono Player.
Actually the Flare R2Pro might do better with an amp. They play loud on the Pono, but I always feel they might be capable of more. They are about as inefficient as the HD600.
I considered a bottlehead as I build electro mechanic stuff but couldn't be bothered, also I mentioned the Valhalla 2 but as you said and like you I haven't got that much thst needs the power apart from my fostex t50rp.
I wanted something non portable like the schiit stuff but.when I started scouring info the mojo and black label both kept sticking a boot in a lot of the schiit options under £1000 ...im now down to the black label again although I hsve considered Jot with multibit or mojo as the jot will virtually run anything ...il pick one in the end.
