Wow that makes me a little sick! Never want to spend money on gear and have it turn out like that. Fortunately you can return them. Thinking back when Linsoul was selling the T4 when it first came out... If this would have happened with them I would have had to ship them back on my dime. No more Tin audio for me.My very brief one-eared first opinion on the new Tin T4
Faulty mmcx connectors on both channels which causes intermittent sound.
I am not talking about a little loose, they are both very loose.
Unforgivable quality control, so 2 stars out of 5 from me.
Very nice packaging but it is all total BS if you end up with a faulty product.
The very brief testing I did disappointed me with the sound. It was quite analytical and not very musical to me and erred on the steely/harsh side.
Normally I would give a new product the benefit of some burn-in time but not this time with such shoddy QC.
I have done a verified purchase review on Amazon UK but it will take a few days before being published.
The Audio Lounge
- Thread starter OldDude04
Richsvt
I think it funny that the thread about cheap cables seemed to have just found out how good ISN cables are. Nice that we here are in front of the trends.
Whazzzup
Cheap cables? Whazzzthat
Richsvt
I think the term is relative. Nothing is cheap in this hobby
Richsvt
Being a cable junky myself, I like that thread, they uncover some decent deals. Someone is always testing stuff like resistance and conductivity to keep it all honest
rr12267
RIP Neil Peart
Another great one lost![Triport Sad :triportsad: :triportsad:](https://cdn.head-fi.org/e/headfi/triportsad.gif)
Richsvt
Not a good way to start the new year off. Loved Peart, he will be missed.
Richsvt
Not a WOW but wanted to think about Neil. Some ones queued up for a walk:
Gone way too soon.
Gone way too soon.
Richsvt
Well, I finally put my X5iii up for sale. Hadn't been willing to part with it but have had my eye on the DX160 and would like to work towards getting that. I know the BT and wifi has had some issues but I don't care much about that, looking for a great sounding unit with good UI and display. Right now, the X5 is not seeing much play-time so might as well let it go...
majo123
- Jan 1, 2016
I think you will be very pleased with it.
Dobrescu George
Reviewer: AudiophileHeaven
I made another video, this time a simple unboxing and first impressions video about DX160 from iBasso
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
DBaldock9
Question for anyone who's running Linux on their PC -
What are you using to control the settings for the digital audio output (SPDIF) on your Linux PC?
This weekend, I did an upgrade on my PC (new SSDs), and installed Linux Mint (which I was familiar with, after running it on an Asus Eee-PC Netbook).
In my PC, I've got a Syba SD-PEX63081 sound card (Cmedia 8828 chip) - which is only being used for its SPDIF optical (TOSLINK) output.
https://www.sybausa.com/index.php?route=product/product&product_id=122&search=SD-PEX63081
When running Windows 7 Pro on the PC, in the playback device settings, I'm able to configure it for 24-Bit / 192-KHz output, which my Topping D70 displays on its screen, when PC audio is selected on the TOSLINK 4x4 Matrix Switch.
At first, in Linux Mint 19.3 "Tricia" (w/Cinnamon desktop environment), the SD-PEX63081 didn't even show up as an available device - so I tried plugging in a Phiree U2S (USB to SPDIF (Coax & TOSLINK)) adapter.
That worked, to send optical data to my D70, at 48-KHz (even though the U2S is rated to 192-KHz @ 16-Bit, or 96-KHz @ 24-Bit).
After some software updates and a reboot, the Cmedia 8828 began showing up as an audio output device - so I moved the fiber back to the card in the PC.
I've installed a few different Audio Device / Volume Control apps, but haven't found one that allows the digital output settings to be adjusted.
When using several different music player programs, the PC always outputs 48-KHz data - if I'm playing 16-Bit / 44.1-KHz, or 24-Bit / 192-KHz FLAC files.
Any ideas or suggestions? Thanks!
rr12267
did a little searching and it appears cmedia is pretty windows centric but I did find something on kernel.org that “might” be helpful.
https://www.kernel.org/doc/html/v4.14/sound/cards/cmipci.html
DBaldock9
Thanks for the reply!
I'm glad that the card is recognized by Linux - both the Analog outputs (which I don't use), and the Digital output (SPDIF) that I do use. It would be great to find a utility that allows me to set the bit depth & sample rate - or to instruct the card to simply transmit the audio file as-is, up to the maximum supported rate (24-Bit / 192-KHz), and only resample when it encounters a higher rate.
Total: 12 (members: 1, guests: 11)
