CactusPete23
The output impedance affects the amps ability to control the speaker drivers frequency response. Say a speaker has a peak of 2db at 50 hz. A higher output impedance might allow that that 50hz peak to bump up to +3 or 4db. All dynamic speakers have multiple dips and peaks. Look at a frequency response graph. So an IEM's sound signature could vary from low to high output impedance DAPs. Sometimes the sound is subjectively worse, but sometimes it can be an improvement. Multi drivers and crossovers also are harder to drive.
Now the disadvantage of low output impedance. To get low output impedance down in the 1 ohm range the amp has to use negative feedback. Negative feedback can make the amp sound unnatural. Ayre Acoustics hates negative feedback. So the PonoPlayer has none. This means an output impedance of ~ 3.1 ohms single ended or ~6.2 balanced. But every earphone I have compared, including the Trinity Atlas, sounds better balanced. To be fair this might back fire with some of those 8 driver per ear 8 ohm IEMs. I am actually interested in Hidiz now.
Great, Thanks for the explanation ! I did not realize feedback control was needed for low impedance output. Guess Many DAPs with 1 and 2 OHM Impedance, like OPUS1, do that,?
Any idea what the 32 ohm "loaded" output impedance means?
Yes, I'm trying to do what I can with Specifications on the Hidizs AP200, since there are no reviews of the audio available yet.
Also wondering if higher output impedance might also be why some IEMs sound changes on different DAPs ?
Sorry for hijacking this thread with a tech question.
