BenF
- Jan 22, 2013
Sounds like you got yourself a v1.I´ve tried out my Takstar Pro 82 a bit now. I´ll probably post a longer amateurish review later, but my initial impressions are that they are very comfortable. The isolation is decent, I like the tonality. The bass is pretty good, not for bassheads or EDM-lovers but I like it and find it quite detailed and fast. Very clear, detailed sound, the strength of this headphone, outside how comfortable they are. I think the treble are a bit too pronounced for me, I´ve played around a little bit with the EQ but didn´t find that I managed to solve it in a good enough way, so far. If I can´t tame the treble a bit more I´ll probably sell them and buy something a bit more balanced and a bit warmer and less analytical. I do get why lots of people love them though, the comfort, detail and clarity is truly great. I also like the tonality.
Early conclusion: Right now I can´t stand the treble so I either manage to tame it or I will sell them fast.
You have 3 options:
1) Tune the v1 with the foam disks: Tuning Pro 82 with easy mods
2) If you want to get rid of the treble peaks, sell v1 and buy the genuine v2 here: https://www.aliexpress.com/item/32808454492.html
3) If you want to get rid of the treble peaks AND raise the bass to bass head level, buy a genuine GM200 here: https://www.aliexpress.com/item/33012705103.html
Keep in mind that while any smartphone will get Pro 82/GM200 loud enough, they won't drive it properly, especially the bass. High quality bass requires a lot of current, and smartphones can't push current, only voltage.
That's why on smartphones Pro 82 will sound treble-happy.
So BTR3K is still needed to get the full potential from Pro 82/GM200: https://www.aliexpress.com/item/4000849710696.html
Bass will get even better with the balanced cables: Using Pro 82 with a balanced cable
If you'll buy Pro 82/GM200 with BTR3K, you can use the 8$ coupon in the first post.
Combined with the ongoing discounts during the sale, it's a pretty sweet deal.
