Hirogoshi
Yeah, they are extended the same. It's probably just because they're new and that the clamp force will weaken over time to what the older pair has. I've heard that is common in headphones. However, the softness of the pads, as noted in the diyaudioheaven comparison, is said to be a difference between revisions. This change lines up with mine, unlike the shape of the earpads. But, it may be yet another sample variance, or like you said, just something that will improve with time.The clamping force should be the same - are you sure that both headbands are extended in exactly the same way?
The foam may fell firmer at first, but with use it will probably soften up
