That's what a perfect amp should be - a "wire with gain":
http://nwavguy.blogspot.com/2011/07/o2-headphone-amp.html
When I "truly" entered the hifi world, I had some philips citiscape downtown. They are somewhat hard to drive. I had by the time the Xonar U3 which has a fixed amp value (16,32,64 ohms). The HPs were still kinda mooshy in 32ohms and the sounds were too enclosed, hearing my friends over teamspeak while in a match was a pain because their voice could get lost so easily with the figthing sounds... but putting 64ohms was like being enlighted. The soundstage become wider, everything become crisper (but not harsh brighted), the voices of teamspeak weren't mixing and they were clearly separated from other sounds. Then I got the Prodigy Cube Black which is a fine DAC with mic in and I gifted the U3 to my father. Since then, I havent got really the chance to buy another U3, either it is way too expensive (3 times the price I got it) or sometimes they even aren't available.
I have the O2 and had for some time a Magni 3 but I couldn't get the same results on those philips like with the U3, even with the high gain buttons.
The thing is, I feel somehow in the same situation as the one I just told. I feel like I need to give the GM200s an extra punch to become crisper... I just need a kick in the mid-highs.
Maybe I'm just rushing my ideas, but I truly feel some harmonic distortion with some songs.
I will try to save to buy the synergy combo and the Pro 82's, I still have high hopes to make them run properly. (and I just love their comforntness)
Edit update:
I just found my 3.5-6.3mm adapter. Audiotrak once told me that the 6.3mm plug is uncapped (maybe they limit the amp of the 3.5mm to 32ohms? I never knew the answer to that).
I inmediatly felt the difference, even the volume is different (I'm now like at 20% when before I was at 60%). So the problem was that they weren't really properly amplified (they still are not). The vocal has more pressence and there is less distortion. I still feel they need more amp, but now I don't feel the doubt of returning them by the probabilty of gotten a bad unit.
I will try to make a recording when I have time, maybe it can be noticeable there.
