Arnotts
- May 15, 2011
I've used the Subpac with both of my rigs. Here are the two ways I've set it up.
With the Gustard X12 + H10, I hook up the H10 to the X12 via the balanced XLR outputs on the X12. I then hook up the Subpac to the unbalanced RCA outputs on the X12. The X12 outputs sound via the XLR and RCA outputs simultaneously, meaning I connect my headphones to the H10 and the DAC outputs to the Subpac in perfect sync. You can turn the volume down on the X12 itself to help fine tune the intensity of the Subpac, and then change the volume on the H10 for your headphones. I hook up my monitors to the line-out of the Subpac (this means that I can only use my monitors while the Subpac is on, but this isn't an issue because you can turn the intensity to 0 if you don't want to use the Subpac).
With the M-DAC, I've daisy-chained ANOTHER DAC to solely handle the output to the Subpac. I've connected the M-DAC to my M-Stage DAC via the optical out, and hooked up the Subpac to the RCA outputs on the M-Stage DAC. I've connected my monitors to the RCA outputs on the M-DAC, and I drive my LCD-X's from the balanced XLR outputs on the M-DAC. This means I get synchronized sound to my headphones, monitors and the Subpac. The reason for the existence of the M-Stage DAC to solely handle the Subpac is because the M-DAC does not allow simultaneous use of headphones and the RCA/XLR outputs, only one or the other.
The Subpac only starts working for frequencies that are 120hz and below (IIRC). Your headphones will still reproduce bass just like they normally do, but you get the added benefits of the Subpac, which, when set up correctly, feel like a perfect extension of the bass from your headphones/monitors. You can literally FEEL how well a producer has mixed their bass, which also travels through your body to yours ears, which lets you hear more as well.
Basically, I really like this device. It's helped provide the experience that I've been searching for for a long time from headphones.
EDIT: For anyone who owns the Subpac and has a nice pair of speakers/headphones, listen to the song Stigma by Noisia. A masterpiece of bass music.
