Stax: SR 002 + Srm 002 and Srm 003 mk2 + Srm 003 impression and appreciation thread
Nov 4, 2012 at 2:50 AM Post #92 of 829
Does anyone know if the new SR-002/SR-003mkii has the same type of tip attachment as the original? I would want the Starkey custom tips but they are made for the last gen so I want to make sure they would work fine on the new model too.
Also, it would be interesting for experienced Stax users to listen to the SR-003 Mkii on the same amps they use for their fullsize Stax. Eliminating variables for scientific purposes and all that...
Nov 4, 2012 at 3:11 AM Post #93 of 829
Actually, the diameter of the tip is smaller this time so I don't believe you could use an old mold.
Nov 4, 2012 at 7:58 PM Post #95 of 829
Because it is different. They are not compatible. If you want the portable set up, then the headphones will have a jack for the portable amp. If you buy the home set up, then the headphones will have a standard Pro connector to work with any Stax Pro amp. If you want to listen both portable and on a home amp, then you have to buy two pairs of headphones for the different connectors.
Not the greatest solution, unless you're trying to sell more headphones...
 OR....
You can look for an SRD-x or SRD-p portable amp that has the 5-pin pro adaptor.  They are not plentiful but do appear on the web from time to time.  That way you can get one headphone and have one amp for home and maybe one portable.
Nov 4, 2012 at 8:16 PM Post #96 of 829
1. The Starkey tips are complete customs.  I sent them the headphone sans cable so they could make both ends custom.
2. I have used the SRD-p (amp) with both the SR-404 signature (and the SR-lambda pro before that) and the SR-003.  With the ear molds the sound is really close in the mids.  I think the sound stage on the SR-404 is better and the "sense of ease" is more apparent.  The top end is more extended and tilted up a bit on the SR-404.  Now remember, STAX has improved the thinness of the diaphragm to make the latest even more responsive and linear.  I can tell you that the difference between the lambda pro and the SR-404 signature was striking in terms of clarity.  I can only imagine that the newest SR-003 might be better that the SR-003 that I have.  I have heard the SR-007 (Omega) on the SRD-p and the sound was spectacular but not better enough to justify the extra expense.  It may have been the amp that was holding the SR-007 back but I heard them both (Omega and SR-404 sig) the same day on an 007t and was surprised that the difference in amps (SRD-p and 007t) was not all that apparent.  Just my opinion, I was expecting more.  I left the venue satisfied with what I am using.
Nov 4, 2012 at 10:14 PM Post #97 of 829
Yeah, they are IEM's attached to a head "band" or "strap" so would it be a headphone?
IEM with a head band will still be an IEM. This isn't IEM by definition because it doesn't require a seal in the ear canal. That means it should be like an earbuds rather than an IEM.
Nov 4, 2012 at 10:42 PM Post #101 of 829
Nov 5, 2012 at 7:15 AM Post #104 of 829
hmm, interesting....pro bias ayeee
