Melvins92
Whoops, I was banned already under another user name.
- Feb 11, 2011
how long do you have to heat the cups for the plastic ones for the glue to melt?
I only did mine for like 10 seconds and pulled REALLY hard. I guess like 30 seconds on low heat should do the trick.
I'm considering trying this. Quarter mod if necessary, along with dampening the cups, maybe replacing them if I can source them for a reasonable price. Is there any real advantage to using the sr225i as the starting point?
To my ear, no. I've modded both and there has been 0 difference between the two. Sell the 225is and pick up some 60is and a pair of woodies.
Hi Everyone,
Alright, first and foremost I would like to thank Bill. I have honestly never met a person on any forum who has been so gracious and generous. Below is the first attempt at the grado sr 60 mod. I used jatoba for the shells... Let me know what you guys think.
Cheers,
Al
[snip]
I started thinking about all those people who can't afford the exotic tonewoods, students and others who, for one reason or another, want to dump the plastic but just can't afford to grab the brass ring. That's when it occurred to me that poplar might be a good place to start.
Popular is an inexpensive wood that skews toward the softer side. Its light weight and light color make it an interesting alternative to the more expensive tonewoods.
While it doesn't hold a candle to mahogany, cocobolo or Brazilian rosewood, poplar is still a better choice than plastic. What's more, because of its lower price, there's less of a need to stick to a single color pattern. The nearly broke could still display high creativity in coming up with new looks for Grados.
These are not completely finished. They need another three coats and some additional sanding to be anywhere close to complete, but the sound on these - while not as defined as it would be in the mahoganies, cocobolos and Brazilian rosewood - is still a step up from the original plastic.
I'm not presenting these as the acme of woodwork. I just think they represent some of the many possibilities waiting to be explored.
