[size=medium]
Hi guys, this goes slightly off-topic, but since all the grado modders are in one thread I'll post here instead of in the DIY forum.
When I was punching my holes in the back of the felt my pencil tip broke off and rolled inside
(I mentioned this about a week ago). It is impossible to get it out without taking it apart. At first I didn't hear it, it was like having a hair on your driver, but today i turned them on and you could hear it (loudly) banging against the diagphram. I'm afraid to turn them on again for fear of damaging them. They are unusable till I get this out.
Any way, this site
http://gilmore2.chem.northwestern.edu/projects/showproj.php?file=grado_prj.htm gives the vaguest possible explanation on how to take that part of the headphones out. I've sanded the tabs that keep it in place, however it seems to be glued in or something.
Please help
[/size]
I can help you. Today, I had a wonderfully insightful experience removing drivers from the plastic. It simply involves a bit of patience - and a screwdriver.
Start with the screwdriver. Better yet, start before the screwdriver. These drivers are held captive in their plastic prisons by glue. It's not thick glue. It's not the same kind of gooey stuff that holds the shells together. Whatever it is, it's relatively brittle. Pop the seal, so to speak, and you're on your way home. I've added to my bag of tricks a fairly old trick - that of steaming the area to be worked on. I don't know if it really works, but it seems to make my job a little easier.
When I first started doing this, I used a steak knife. Not a good idea. You want something sharp but not that sharp. On the other hand, you're trying to get into a fairly small place so it may help to have something a little finer to work with. These are what I had.
The name of the game is to get in there with a screwdriver and start working things loose. You don't want to go hog wild. The metal that encases the frame is malleable, but that also means it's bendable. You don't want to emerge from this with a driver that looks like it got into a bar fight, so use patience and just keep working your way around the circle. At first, this will seem pointless and absurd. Just keep at it without losing your cool. It's tedious but not impossible, even if you're all thumbs. Just keep working the loop until you hear a "crack."
The "crack" is not the end. To quote Winston Churchill, "It's not the beginning of the end. It's the end of the beginning." You want to keep working that plastic loose and applying pressure as you go until little parts of the seal start coming undone: "Crack," "crack," "crack."
When I say this work is tedious, I am not kidding. Unless you are Mr. Slick and you solve Rubik's cube at breakfast every morning, you're going to be at this for a while. Don't beat yourself up. That's the price for getting this sucker out of there. The unreligious will find God; the pious will utter curses that are not to be repeated. Once you get some leverage, that's when you start using it to force the driver up. I like having more than one screwdriver around, so that when I've got movement on one corner, I can hold it there while I put a second screwdriver to work. Otherwise, it's like climbing Mount Kilimanjaro - two steps forward, one step back.
If you're lucky, you'll pull out a driver that looks as smooth as a baby's bottom. So, the question you have to ask yourself is, "Do I feel lucky?" Well, do you punk? As often as not, you may just end up with something that looks more like somebody's mother-in-law, or Roseanne Barr, or the results of some fifty-year-old's last colonoscopy.
Don't be afraid. To paraphrase the makers of the Asgard Amplifier, Shiit happens. If you want to wear that Masters' jacket, you have to play through it, Tiger. Even a car wreck like this can be fixed. This is where you go Nip/Tuck all over this thing.
Just look this bad boy straight in the eye and say, "What is it you don't like about yourself?" Then schedule it for a little lipo and botox. I read somewhere that tape could be used for this purpose and I'm here to say, I didn't hear wrong.
As Barry Scheck would say, "There, Mr. Feng!" Slap on the tape, smooth it over the dent, and then lift. Don't go crazy, just "Get'r done."
Too bad, you can't take the dirt with it, but that's an issue we'll leave for another day. The point right now is that you don't have to live with wrinkles. You can Joan Rivers the whole driver. Do it right and you'll erase more sins than a priest on Easter Sunday.
This . . .
. . . can be turned into . . .
This!
It's absolutely therapeutic. One minute, you feel like Britney Spears, running from Dr. Phil as he barges into your hospital room saying, "How's that workin' out for ya?"
The next minute, you're free. Life is good. Your worst fears have been shattered by your steely resolve.
In the meantime, your drivers have you to thank for springing them from this plastic Alcatraz. Is it just me or does this thing look like a mask worn by a machete-wearing psychotic in a horror franchise?
It's time to drive a stake through the heart of this plastic monster. While you're doing it, don't let up. Just keep telling yourself, "Mercy is for the weak."
I wasn't done when I flashed this picture, but I was still pretty jazzed. With liberated drivers, you can unleash the potential of your Grados.
