Analysis paralysis though, I can see that being an issue with newcomers to the hobby. But I get your point and agree, more options and more competition, the better for us consumers.At one point, they mention the abundance of amp selections as another 'downside' of speaker amps. Like come on lol..
Speaker amps for headphones
- Thread starter Operakid
- Feb 3, 2017
Meh. There are an abundance of headphone amps to choose from as well.Analysis paralysis though, I can see that being an issue with newcomers to the hobby. But I get your point and agree, more options and more competition, the better for us consumers.
number1sixerfan
Although that last part is very true, that wasn't my exact point.
Like mentioned above, it was just a poor and moot point as it's the same exact case for headamps. And more importantly it was a totally irrelevant point for the topic at hand (safety), which kind of exposes the agenda here (among other giveaways in the video).
+1
On an entirely different note, do you @number1sixerfan or anyone else have recommendations on short speaker cables that you have liked, when connecting the Raal interface box with your stereo amps? Or for connecting the Hifiman HE-adapter with said amps?
I am not looking for night-and-day sonic differences, but want to use good quality cables.
number1sixerfan
Right now, I'm using the short speaker cables that came with the Raal box. But I'm going to order Moon Audio cables pretty soon. I have a few of their shorter cables (hugo 2 > mscaler, headphone > speaker tap), and I've been pretty impressed with their quality and ergonomics. Just very well made and they customize based on your need.
ThanatosVI
Is there a higher quality Version of the Hifiman Headphone adapter, that is readily available?
Including resistors, so that it is also useable with tube amps.
paradoxper
Bingo. And they are playing conservative.Most (not all) solid state speaker amps are fine with the higher load.
However among tube amps it's a lot more common that they have trouble with the high load, causing damage to the amp (therefore it's generally advised to use parallel resistors)
The problem is, that you can't generally say it's fine, for those cases where it's not (while you can always connect it to a headamp, without causing damage)
What they are basically saying is name me x headamp that poses a danger for our headphones. And they'll name you xyz speaker amps which are problematic.
iano
- Feb 12, 2003
Personally, I have had great results using the services of Zynsonix (Bryan Fox). Nicely made boxes and I think if you tell him about the amp you are using he can recommend the appropriate combination of resistors to get the right balance between noise and volume. It takes about 3 weeks or so to receive the box after an order (in my experience). I have order two boxes from Bryan in the last year, and a cable with no resistors (I added the protective resistors to the amp speaker outlets). All have functioned excellently. I do not use tube amps BTW, so I probably do not need those protective resistirs technically, but I play safe anyway.Is there a higher quality Version of the Hifiman Headphone adapter, that is readily available?
Having said that, its also fairly simple to not only add resistors yourself to the speaker outlets on the amp, or make a box yourself, adding those prtective resistors in the box. I count myself pretty much a newbie solderer, but I made two boxes myself just using the robinette box web pages and Bryan's own diyaudioblog.com site, and just cheap wooden craft boxes. Not cheap to buy them ready made, and if you are into DIY you can get to choose whatever boutique resistors you want idf you are into that sort of thing Personally, I just used good quality Mills ones and the results have been excellent, its not a pretty sight, but only I see it, so I fine with functional and ugly! If you wanted more details we could converse via pm.
ThanatosVI
P.m. sentPersonally, I have had great results using the services of Zynsonix (Bryan Fox). Nicely made boxes and I think if you tell him about the amp you are using he can recommend the appropriate combination of resistors to get the right balance between noise and volume. It takes about 3 weeks or so to receive the box after an order (in my experience). I have order two boxes from Bryan in the last year, and a cable with no resistors (I added the protective resistors to the amp speaker outlets). All have functioned excellently. I do not use tube amps BTW, so I probably do not need those protective resistirs technically, but I play safe anyway.
https://ampsandsound.com/products/black-box-headphone-adapterIs there a higher quality Version of the Hifiman Headphone adapter, that is readily available?
deafenears
Someone else posted the internals of one on another forum and doesn't look to have any resistors?
ThanatosVI
The current Box if ordered from the website has no resistors.Someone else posted the internals of one on another forum and doesn't look to have any resistors?
Older ones used to have some and they can also add some on special request via email inquiry.
ThanatosVI
I googled Zynsonix.Personally, I have had great results using the services of Zynsonix (Bryan Fox). Nicely made boxes and I think if you tell him about the amp you are using he can recommend the appropriate combination of resistors to get the right balance between noise and volume. It takes about 3 weeks or so to receive the box after an order (in my experience). I have order two boxes from Bryan in the last year, and a cable with no resistors (I added the protective resistors to the amp speaker outlets). All have functioned excellently. I do not use tube amps BTW, so I probably do not need those protective resistirs technically, but I play safe anyway.
Their boxes seem to be perfect, even with switch between resistor network and direct connection if one chooses to take it. The minimum config is also very attractively priced.
Premium components are expensive but you know you got the good crap
smodtactical
- Nov 11, 2012
On the forge headphones.com live stream on tylerseclectic they were basically saying power amps with headphones are really risky. Tyler saying people can get electrocuted by speaker tap cables. Lol
ThanatosVI
Well if you apply them directly to your nips instead of headphones or speakers, I consider that a possibility.On the forge headphones.com live stream on tylerseclectic they were basically saying power amps with headphones are really risky. Tyler saying people can get electrocuted by speaker tap cables. Lol
