yea it is not possible to use an adapter to make SE cable balanced.I wouldnt use the stock cable, period. I am using my LG V60 using UAPP with a Gothic Audio all silver USB C- micro into the Walkman input. Volume set to 50% in the app, it would destroy my hearing above -20db on the TA. Norne Audio silver Draug hp cable, which when i purchased, the first thing o initially noticed was i had to lower the volume compared to stock.
I have emailed Trevor @Norne about an adapter but im not sure if that's possible on a single end cable with a 1/4" jack?
I don't know the technical term here, it is like a phone could make z1r loud enough, but clearly phone doesn't sound good. Same thing with the balance on TA.
And from my understanding amp power has more things to do rather than just higher volume. Anyway, if you got stock 4.4 cable why dont give it a try
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
