Reeshar
- Feb 4, 2005
Got my N3s. Sound amazing but I'm so bummed that these amazing Sony tips are so damn big. Smallest is just a hair too big. I can create a seal and hold but it takes a lot of pushing. One little tug and it's out.
What are my options for most similar EQ? Is the Comply tip going to be a downgrade?
Personally I didn't get on with any of the Sony tips provided with the N3s. I'm more used to the conventional memory foam tips from companies such as Comply, but I don't get any sense that price is a good guide to the ones that fit best. In fact I found some really cheap small tips on Amazon that sit really well in my relatively small ear canals:
https://www.amazon.co.uk/gp/product/B07D8WFH16/
The 4.5mm tips fit the N3s perfectly (the N3s are 5mm in diameter), and the small size tips seal well in my ears and are very comfortable.
