reyven
- Sep 16, 2007
Where in Tokyo are you guys picking up the black WF-1000MX3 ? They seem to be sold out everywhere?
I don't usually use the Z1R as an wireless option. That won't be doing it justice. Only for specific situations, when I am too lazy to lug the WM1Z around the house.
I don't know about the BTR3 or ES100.
Yes, the WF sound is more than good enough for causal listening. Because it has that signature Sony sound, it's relatively easy to EQ, making it sound like the Z1R. A very "unpolished" version of it, of course.
The one big negative, are the connection dropouts. No matter the distance, they happen rather frequent (my guesstimate... once every 15-20 mins???). Definitely more than the competition for sure. I hope Sony can have this resolved through FW.
At least the graph is not showing a drastic peak, but small one at 8k. This is Crinacle's graph, and I'll look into doing a measurement myself once I get a hand on one.Anyone finding these (mark 3s) bit treble peaky? Like there's a narrow but high bump somewhere 10khZ + makes them sound steely and high hats prickly... I'm hoping burn in will help.
Interesting, maybe it's the huge dip at 1k and peak at 3k which could be the issue... Looking forward to seeing your measurements.At least the graph is not showing a drastic peak, but small one at 8k. This is Crinacle's graph, and I'll look into doing a measurement myself once I get a hand on one.
That's really not dips or peaks actually. The way it looks is a typical iem response curve. It's pretty standard to have a rise going from 1k toward 3k or so, and then a slight decline toward 7-8k or so, and then a sharp dive if following something called a 'target curve.' Harman would be one target curve. Here's an overlay comparing the Harman curve to Sony's response and it's close. When I look for peaks, it's either ones that are quite drastic or if minor, relative to target curves (deviations from target curves).Interesting, maybe it's the huge dip at 1k and peak at 3k which could be the issue... Looking forward to seeing your measurements.
Comparison to another 'target curve' called Diffuse Field
In my experience, peaks tends to be less dramatic with iems. I too like the smooth nature of 650's presentation, but with these, I don't see any crazy peaks to be concerning. I will need to still hear it see how it sounds overall of course. Close to 10kHz and beyond are not reliable with measurements. It's not even certain that slight peak at 8kHz will be at that spot for your ear compared to the ear simulator.Thanks for this - good too see that actually they're somewhat close to harman.. I do find them relatively balanced, it just that as I suspected from these graphs the highs at 15khz (and maybe the small peak at 8) coupled with the slightly steely nature of its highs (not sure maybe bit grainy, AAC adds to this also perhaps), it's something that sticks out a bit too much for me.. mind you my favourite HP is HD650 so maybe that's why I'm more sensitive to this. Good things though, the sony app eq allows for 15khz trimming which helps.
Three weeks of use now and I can elaborate a bit on my earlier comments.
-Battery life is excellent. 6 hours is no problem with DSEE engaged and mid-level on volume with full ANC engaged.
-ANC performance in a transpacific flight is about 85% that of the WH-1000 XM2 (I don't have a model XM3)
-No problem lying on a pillow in a first class flat seat.
-Sound signature is superior to that of the previous WF-1000X. ANC is FAR superior. Probably 70% better.
-They are unobtrusive, I use the putty color ones at work and no one ever seems to notice they're in my ears... the black ones are much more obvious. I use those at home.
-Absolutely useless under a race-fit motorcycle helmet. (As expected)
Unlike the poster above, my connections have been absolutely rock-solid (set to emphasis on audio quality). Latency is somewhat variable- on my iPad Pro with locally stored movies and Youtube, it's almost nonexistent. On some Amazon Prime streaming videos, I have noticed some latency. Both of these source related phenomena are less noticeable on my iPhone XS. Locally stored video has no visible latency, streaming stuff from Youtube has none, and from Amazon Prime it is barely there.
Hit me up if you have any questions.
For me, going from iPhone to iPad and back, step 3 is all that's needed. The only unfortunate things is, I have two units and they can't be renamed in iOS, so I have to remember which one in the stack is the one I'm using. Not difficult.Hey GatMan, thanks for the insight so far.
What are the steps to switch between the iPad and the iPhone for this? Is it still the same old steps below? Or could you skip steps 1 and 2?
1) Turn headphones off
2) Turn headphones back on in pair mode
3) Go to Bluetooth settings in the iPad/iPhone and tap on the headphones
Much appreciated.
