jeez.. i am so tempted to get these now...
praying hard that they arrived in SG soon.,
ANC on the 1000X made practically no audible difference so it had better be a lot better ! On the other hand the WH1000XM2 offered excellent ANC so if the WFxm3 are possibly better that's a game changer for TWEs ! Have you been able to do some more tests ?
Got my WF-1000XM3 today... Was pleasantly surprised by the sound.
I think it might just beat all the portable wireless solutions that I have, in terms of overall sound, fit, usability, features and battery life.
Beats Powerbeats Pro Wireless
Sennheiser Momentum True Wireless
Audio Technica AT-PHA55BT
Astell&Kern XB10
Sony MUC-M2BT1 + Sony IER-Z1R
The case looks big. How does the sound compare to the Senn MTW? Considering the switch, as I'm not too much a fan of the design. The bass on the MTW is also a bit much, however, I like the soundstage.
If you like Sony's house sound, you would much prefer the WF-1000MX3. The bass is a tad lighter on the Sony. Sound stage feels wider on the Sony, further amplified by the V/U shape sound.
On my ears, the Sony fit better, although the Senn felt more secure. Battery life is pretty obvious from the specs. ANC is a big big feature, you can hear the immediate difference especially on the streets. At the same volume, the Sony's are louder. Big plus. The app... Senn's app is pathetic, let's just put it that way.
Now that I have both, I kind of regretted getting the Senn, especially when it cost me a lot more. Guess I will be giving it away to my other half. That would make her happy.
Hows the ANC performance? I'm curious how it stands against the full-sized XM3's ANC performance.If you like Sony's house sound, you would much prefer the WF-1000MX3. The bass is a tad lighter on the Sony. Sound stage feels wider on the Sony, further amplified by the V/U shape sound.
Cant beat that Muc BT Z1R combo though....I hopeGot my WF-1000XM3 today... Was pleasantly surprised by the sound.
Astell&Kern XB10
This guy does a test, but it's weak. If he did a test under high airplane engine noise environment, it would be respectable. Also, he says over the ear cans have better noise isolation than iems? I always thought iems did? I can't share his enthusiasm for the full-size XM3's bass quality.
Hopefully, another reviewer I know does a better ANC performance test video as he does really good ones.
One thing I wish the WF-XM3 had is wired connection if used for inflight entertainment.
Cant beat that Muc BT Z1R combo though....I hope![]()
Definitely that combo sounds best. But when on the move, it is cumbersome, and lack the features you would want in a wireless setup.
Great when doing chores in and around the house though. Connectivity and range is excellent plus it has LDAC. As a standalone receiver, it is better than the AT & AK.
How about something like BTR3 or ES100 with a short MMCX?
Does the BT neckband affect much to the sound compare to wire?
All these might just force me to sell my collection and get Sony WF. The sound seems to be good enough
