DMP-WM1 FE (Final Edition)
As the aim is to get the best sound possible, the previous DMP-WM1 and DMP-WM1 II custom
firmware versions are no longer available. DMP-WM1 FE replaces them both.
The name "Final Edition" was chosen instead of simply "DMP-WM1", so people would know that
they have installed this firmware, and not the first version.
Update:
- improved sound signature - fuller, deeper, and more impactful bass, natural and lifelike vocals,
and non-fatiguing and smooth highs, with impeccable details
Features:
- sound signature aimed at resembling the one of the DMP-Z1
- native DSD playback over the 3.5 mm output
- DSEE AI (present on DMP-Z1)
- progressive JPEG and interlaced PNG album covers are supported
Installation:
1. Install DMP-WM1_FE
2. Install DMP-WM1_FE_Ext_Tuning
To revert to the stock firmware:
1. Install StockRevert_(DMP-WM1_FE)
2. Install StockRevert_Ext_Tuning
When installing DMP-WM1_FE or when installing StockRevert_(DMP-WM1_FE), the player
should restart and go into update mode. The update bar on the player's screen should fill up
to the end. Otherwise, you won't be able to install the external tunings.
What should I do if I'm using one of the previous DMP-WM1 custom firmware versions?
1. Revert to stock using the StockRevert of the respective firmware (for example, use StockRevert of DMP-WM1 II if you have DMP-WM1 II installed)
2. Install DMP-WM1 FE
3. Install DMP-WM1 FE Ext. Tuning
You can find the StockRevert for the previous DMP-WM1 and DMP-WM1 II custom firmware versions on the link below.
I would recommend giving more listening time to DMP-WM1 FE first, in order to get accustomed to the different sound signature
before eventually deciding that it doesn't sound as good as DMP-WM1 MK2. "Brain burn-in" is a real thing.
Download DMP-WM1 FE here.
Feel free to leave your feedback, and enjoy!
