# [Walkman One] #
www.mrwalkman.ml #
# Mod Settings #
# SOME INFO - READ ME PLEASE! #
# This file is automatically generated if it doesn't already exist.
# You can find more info about each setting below.
# I recommend editing this file with a basic text editor, like
# Notepad or Notepad++ (Wordpad should be avoided).
# There should be no spaces after the value of a setting.
# For example, the region should be [REG=U], and not [REG=U ].
# If a setting cannot be found, the default value for
# that setting will be used (check the default values below).
# You can check the [boot_log.txt] file in the CFW folder in the
# internal storage to make sure that everything you set here is
# being read and set accordingly.
# Turn off the Mass Storage settings after modifying and saving
# this settings file.
# Reboot the device after changing any settings in this file.
# [SOUND SIGNATURE]
# Choose between 4 sound signatures.
# After changing the sound signature here you need to reboot the
# player first, and then to apply the corresponding external tuning.
# Available options are:
# 0 for Neutral - between Warm (Midnight) and Bright (Dawn)
# 1 for Warm - Midnight v2
# 2 for Bright - Dawn v2.1
# 3 for WM1Z - the WM1Z stock sound signature
# For example: SIG=1
# Default is [3].
SIG=3
# [REGION]
# Available regions from the destination tool:
# J, U, U2, U3, CA, CEV, CE7, CEW, CEW2, CN, KR, E,
# MX, E2, MX3, TW
# Any of the regions above will bring a change to the
# sound signature.
# Type the chosen destination after the equal sign (no spaces after).
# For example: REG=E
# Default is [MX3].
REG=MX3
# [REMOTE OPTION WITH ANY REGION]
# Show the bluetooth remote (RMT-NWS20) option in the UI, with any
# region. The region you set still has its same effect on the sound.
# Type 0 for Off, or 1 for On.
# For example: REM=1
# Default is [0].
REM=0
# [PLUS MODE VERSION]
# Choose between the v1 Plus mode and the v2 Plus mode.
# While using the Plus v2 mode and playing audio via BT Receiver
# while the screen is off, the audio may glitch. Force restart the
# player by holding the power button for 7 seconds if this happens.
# Type 1 for the v1 Plus mode, or 2 for the v2 Plus mode.
# For example: PMV=1
# Default is [2].
PMV=2
# [PLUS MODE BY DEFAULT]
# Choose to boot by default into the chosen Plus mode or not.
# While this option is On, the Hold Button UP position must be used
# if you want to boot into the Normal mode.
# While this option is Off, the Hold Button UP position must be
# used if you want to boot into the chosen Plus mode.
# For example: PMD=0
# Default is [0].
PMD=0
# [GAIN MODE]
# Choose to have the gain in its stock state, to have a
# higher gain, or to have a lower gain.
# Type 0 for Normal, 1 for Higher, or 2 for Lower gain.
# For example: GMD=1
# Default is [0].
GMD=0
# [DAC INITIALIZATION MODE]
# Choose to initialize the DAC differently, which alters the
# sound signature.
# Type 0 for normal initialization, or 1 for the different one.
# For example: DIM=1
# Default is [0].
DIM=0
# [HOME SCREEN ICONS COLOR]
# Make the icons on the Home screen have different colors.
# Available options:
# 0 for DEFAULT (#DDDDDD)
# 1 for PEACH (#FFD2B0)
# 2 for RED (#FF6757)
# 3 for BLUE (#B1CFE5)
# 4 for GREEN (#AED1B3)
# Type the chosen color after the equal sign.
# For example: COL=2
# Default is [0].
COL=0
# ENJOY THE MUSIC! #
Your right, stock.
