MrWalkman
Is it possible that the Z and FEv2 are the same size and named the same when downloaded?
Yes, if you take a look inside you'll see that both firmwares are in there.
Bummer. I may need to revert to DMP-A40. Still it is amazing to have all these great choices. Thanks.Because the stock A50/A40 firmware doesn't have that ability.
I may give the ZX300 firmware another try in the future.
Thank you very much!Yes, if you take a look inside you'll see that both firmwares are in there.
Virtual beer(s) sent.
And thanks for making so easy to change/revert!
What! (World Trade Federation!) I made sure it was on the J setting. I have already reverted back to DMP-40, but simple to change & check again. Which version is yours @? FEv2, or Z? or something else?Hey, I checked now on my A40 with the J region, and I can see the "Remote Control Settings" menu.
This menu will only show up on 2 or 3 regions - I know at least J and E.
Well, I had scrolled down and didn't find it. I'll try again in a while (after dinner). For me with my use of the A45 as the travel DAP the remote is a must - worth more to me than having the WM-Port line out.Project Z, but it doesn't matter, at least as long as it's one of these newly released firmware versions (including the A50-stock-based unofficial stock update).
The button at the top of the Settings list is not visible, as that place is occupied by other buttons, but the Remote option can be found down in the list.
Easy to change again and try.
Did not find it there before. Begs the question, under the unit info is there also the section specific to the J region, Certificates? That was not present so I used the Dest tool to insure that I had J region. It said I did. But I still did not have Certificates present. (?!)
Thanks for your attention to this,
