Here is my configuration of foobar2000 for upsampling to DSD256 on-the-fly
I presume foobar2000 and Sony PHA-3 ASIO driver are installed.
Components used:
SoX resampler ( http://www.hydrogenaud.io/forums/index.php?s=67eb254fcb55c113709821d94d801774&showtopic=67373&view=findpost&p=600000 )
There are 3 versions. Normal, mod and mod2. You can download all 3, but we need just mod and mod2.
ASIO support ( http://www.foobar2000.org/components/view/foo_out_asio )
Super Audio CD Decoder ( http://sourceforge.net/projects/sacddecoder/files/foo_dsd_asio/ )
Grab the latest version (as of writing this foo_input_sacd-0.7.8.zip ) and extract it. You will get ASIOProxyInstall-0.7.2.exe. Install this following on-screen instructions. You will also get foo_input_sacd.fb2k-component.
Load all components to foobar2000.
At foobar2000
File > Preferences > Playback > DSP Manager load both Resampler (SoX) mod and Resampler (SoX) mod2
Select Resampler (SoX) mod and click Configure selected. This is for sampling rate 44,1k and multiples. Don't forget set quality to Best.
Select Resampler (SoX) mod2 and click Configure selected. This is for sampling rate 48k and multiples. Don't forget set quality to Best.
File >
Preferences > Tools > SACD set Output Mode to DSD
File >
Preferences > Playback > Output > ASIO select Run with high process priority, if you are running 64-bit system select also Use 64-bit ASIO drivers
double-click foo_dsd_asio
File >
Preferences > Playback > Output select ASIO: foo_dsd_asio as Device. I use Buffer length 50 ms.
That's all. During playback both PHA-3's LEDs, Hi-Fs and DSD, should lights up.
You can try this free DSD64 sample Michel Godard MONTEVERDI: A trace of grace www.hifistatement.info/download_godard/A_Trace_Of_Grace_1-28.dff
