djricekcn
- Dec 2, 2014
Thanks for the information
My PHA3 arrived and the plastic outer cover is kinda worn. There was this clear tape securing the Sony box, but not the fancy clear tape on my NW-ZX2. Is there a way to look up date of manufacture? serial is 7200608
No you can't tell from the serial number. Mine is a Japanese model and starts 7003xxx and it is very recently purchased too. I don't think they are selling these in the many thousands. There was no tape seal on mine either....When you talk about plastic outer, you are talking about the outer cardboard? I assume the device itself looks pristine and all the cables are in their plastic sleeves still?
Few pages back, there was a method of setting Foobar to work with PHA-3, which I can do, but when I try to use my other amp (CEntrance Mini DAC), it doesn't work and I have no idea what to do...i tried doing the reverse procedures but i keep getting Unrecoverable playback error: The parameter is incorrect. (0x80070057)
I charged my new PHA3 overnight, I think it was fully charged.
I ran it straight for about 7 hours and it stopped on a dime. Is this normal?
I am recharging it.
I played beautiful vocals, BTW on my Momentum 2 and Denon 7000.
I haven't timed mine but six to seven hours is about what I'm getting. I haven't played it until it just stopped; when the green light starts to flash I assume it needs charging. I'm still very pleased with mine.
Yes, the PHA3 itself was pristine. I guess my mind was sway to think there was something wrong when the feel of the unit was not as impressive as the ZX2 or the Hugo. Both of those were dense and substantial. The PHA3 felt light and is it even metal?
It is still charging, Hope to try it after work.
I have your tried the PHA3 in balanced mode? If you own the PHA3, you really need to utilize its balanced output for the best sound. PHA3 on the single-end is not that much better than the ZX2 beside the output power. In balance, it is substantially better.
What output did you use at foobar2000?
What is this rub ber opaque piece that came with the PHA3 for?
Thanks
when i went back to CEntrance, i tried both; CEntrance and also PRIMARY.
something asio won't work on it either (but does on PHA-3 when i plug it back in)
