udesign48
by the way, can anyone confirm if PHA-3 can be powered by USB? can you run PHA-3 just with USB power?
Yes it can. In fact the Euro model has no battery and must use the usbby the way, can anyone confirm if PHA-3 can be powered by USB? can you run PHA-3 just with USB power?
what is this AC version? An upgrade to the original PHA3 ? Or just without battery version?What? really? I want to use PHA-3 as external sound card for my laptop so lithium battery is not needed... I'll be running my laptop at least 14 hours a day so lithium battery can be dangerous in my case.
Where can I buy Euro version PHA-3?
Thanks,
EDIT: Sony PHA-3AC is the EU version... and it's selling for 1300 euros on Amazon Germany:
https://www.amazon.de/Sony-PHA-3AC-hochwertiger-Kopfhörerverstärker-schwarz/dp/B00NHOGHOO
good thinking, I owned the 1z, now if I order the pha-3 then I can compare (from memory)... may be similar sounding...In similar vein, how does the PHA-3 compare to the Sony WMIZ sound?
Better, slightly better. But only if you have good digital cablesIn similar vein, how does the PHA-3 compare to the Sony WMIZ sound?
interestingBetter, slightly better
I know this has been mentioned in the past but I’m still not clear on setup for the PHA3 with my iPhone. I know I can’t get high resolution if I use the lightning cable into the USB port. However, it appears I can get high res if I use the lightning to USB camera adapter.
So that gets me to female USB and it looks like I need to go to Sony’s special micro USB adapter, which is male micro USB. Am I correct that I just need a male USB to female micro USB connector?
In other words, I think I need this?
SIENOC USB 2.0 a Male to Micro USB Female Converter Adapter Adaptor Pack of 2 https://www.amazon.com/dp/B00GIF4E08/ref=cm_sw_r_cp_api_i_WBIjEbWMZBDJ6
Agreed but the PHA3 easily pull ahead on harder to drive headphones such as the HD800 or even the Z7 M2.Better, slightly better. But only if you have good digital cables
