Continuing our off-topic discussion of using a Centrance LX without an amp...
Yes, I read a post once where someone said that a Centrance support rep had said that (see the post, above). It seems you could get more bang for the buck with a DACport than with a DACport LX, if it's true that the LX doesn't really have a line out bypassing the amp circuitry, but Headphonia's review suggests that SQ of the LX is better than that of the DACport - which might be due to his expectations of line out quality vs. headphone out, more than the reality of what he is hearing.
Since making my earlier recommendation, regarding the use of a DACport LX without an amp to drive IEMs,
I've learned from multiple sources that when you use software to reduce the volume heard with IEMs or headphones plugged directly into a DAC, you are forcing a reduction of the bit depth and thus, you are effectively compressing the dynamic range of the recording. That's why the documentation of nearly all USB DACs advise you to turn the software volume controls all the way up to supply the DAC with the hottest signal possible, using the volume control of an amp that's fed by the DAC to adjust the levels heard at your ears.
So... that's another reason to get the DACport instead of the DACport LX, if you're thinking of attaching efficient IEMs to the LX and using software to reduce the volume.
Getting back on topic...
For portable operations, I've been using the Sony PCM-M10 for 18 months now - it's still going strong, despite almost daily use, and I've yet to find anything that comes anywhere near close to offering the quality of its proprietary delta-sigma DAC for the money. I'm completely content with the Sony PCM-M10 line out, even though I've spent many hours comparing it to the admittedly superior, but
not portable, DACport LX, as well as other USB-attached DACs. Yes, it's not the best DAC I've heard, but it is definitely the best
portable DAC I've heard.
I recently Rockbox'd my Sansa Clip+ and revisited comparisons with the Sony PCM-M10 - feeding both of them into my iBasso PB2 with balanced cables to the LCD-2. This isn't saying much for some people, but for those of you who are familiar with the Clip+, the Sony PCM-M10 line out offers a higher voltage input to your amp and a lot more detail even with 16/44.1 recordings (not to mention 24/96). But again, the user interface of the PCM-M10 is not designed for music playback - using it as a DAP is awkward,to say the least.
Mike
