regarding the memory card. I've been using the NWZ-A15 as a gym music player as I like the manual controls. However, I want to use the memory card in my Nokia 808 in order to shoot videos/use the fm transmitter. I cannot see any folders or music when plugged into my PC. Only shortcuts. I think the NWZ-A10 series have their own way of organising music, but all the music doesn't appear on my Nokia or PC. Any help with this please? Sorry to sound like a Noob. I did search already and found some answers regarding creating a /Music folder in the SD card. This will be a future step for me, but is there any way to retrieve the files already on the card? Thanks
with your A15 turned on keep pressing the back button until you've navigated your way back to the home screen.
once there go down on the menu to the center of the very bottom row which shows an icon for a microSD card,when you choose it the words 'SD card settings' will appear,click on that icon,this will take you to the SD card settings menu, once there choose 'storage for file transfer' and then 'location for USB transfer' now you will see the options 'system storage' and 'sd card' navigate down to sd card and press enter. that's it.
now plug your A15 into your computers USB port and (on windows) it will bring up the autoplay folder,go in there and choose the music folder,you are now in your sd card folders where you can add or remove albums/songs or copy and paste them onto your computer.if you are using a mac i believe it brings up the content transfer window,but either way that's how you choose which library you want to view when you plug into your computer.
if after that,once you've ejected your A15 from your computers usb port you want to switch back to where you'll see the A15's internal storage folder again the next time you plug into your computer - just follow the same instructions and choose 'system storage'. once you get the hang of it its really very easy to navigate back and forth between the two.
though i agree it would be nice to be able to view both without having to unplug the Walkman wait for it to create the library then go back into the SD card settings menu and reset it back to either the sd card or the system storage,but , for now i'm just happy to finally have a Sony Walkman with a microSD card slot.
