I've not listened as much as necessary for good comparaisons.
Ciems : Earsonics EM3pro
Coming from the DX50 (1.2.8) the soundstage is more "in the head", timbers are thinner, the bass register is a little bit heavier.
Very immersive and détailed.
Can you please test gapless playback? Also if you have bunch of files in music folder and extra folders within music with albums, does shuffle play only the files in music or dues it also include extra album folders?
Yes, it works.
Sorry, all my music is on the same folder level, i can't test it.
Yes, it works.
it can play it all. but I had my files scanned from the computer already so maybe there is that. the shuffle from "sens me" can be limited (but I couldn't yet find why/how) but going by the "all songs" menu it seems to work just fine with anything anywhere. (given that you're set with "shuffle" and "all range" in your playback settings).
if you format the card with the DAP it will make the usual sony directories already (video, podcast ... ) you have a need for further folders outside music?
oh, well you could always make one directory with singles under music and shuffle that folder with playback range set to "selected range"(meaning the actual folder you're in).
or make a playlist (all you need is generate a .cue with foobar of all the selected songs). but I don't know if there is a limit to the size of a playlist?
anyway you should have ways to do it how you like withing "music" subfolders or outside of it.
