that much is perfectly understandable. you will tend to look for a lot of power and gain only when using a less efficient headphone. so we mostly end up in a nice equilibrium most of the times.
but on all the gears that have not much power or gain to begin with, like smartphones or ... IDK... the A10? ^_^ those stuff seem to be clearly made for efficient IEMs (intuitively at least). yet it's not. it would probably sound cleaner into a nad hp50 or a senheiser urbanite and those kind of easy to drive yet not too sensitive headphones, instead of most ultra sensitive IEMs. because of that annoying default noise that doesn't really go down with the volume setting.
the X1 has more power and gain than the A10 but hisses a lot less into sensitive IEMs like a se535. so it's not a fatality, some people know how to do it right.
but again even with something as limited as the A10, we can still find many IEMs and headphones that are driven correctly, but are not so efficient as to make that noise audible. so the problem isn't really the noise or how loud it is. to me the problem is that the manufacturers don't try to give tools for the consumer to know what headphones would best go with the device.
if I was a trendy and involved reviewer(that must be so much work!!!) I would make up some DAP chart of everything I get my hands on, with some uncalibrated relative value of noise recorded from all DAPs into a very sensitive IEM, with volume level matched at normal levels into the IEM. to be able to say, "that damn studioV was hissing 15db louder than a X1" or something like that ^_^.
so that when people have a DAP and notice hiss problem but want to keep their IEM, they could check that crap chart and at least avoid those with an even greater noise.
ok I just wrote on the top of my head following a flow of ideas, but I guess that could actually be kind of useful to make something like that, given that IEMs and headphones are more and more sensitive every year.
who gets to try loads of DAPs and wishes to waste his entire life doing some silly measurements aside from reviewing the DAPs?
