Raptor34
10mw isn't much, but thankfully the pm-3 is a wonder of sensitivity for a planar.
google tells me 102db and 26ohm (check if I'm right maybe?) that should give you close to 112db with the volume maxed out(that's for peak RMS not for music actually sounding like 112db loud). to clear an amp I'm used to look if it can do 115db so it's not good, but very close still so it's hard to really call that a fail in driving power. if you don't listen loudly or have mostly modern music, it will work.
now from http://headphoniaks.com/blog/sony-walkman-a15-analisis-tecnico-y-review/ they show that distortion goes up to 0.17% into 32ohm and 0.11% into 16ohm, so I would expect maybe 0.15%? at full volume into the oppo. it's not really great TBH. probably because the poor sony is giving up all it can at full volume in that situation.
the mdr1r we talked about it but I still don't know the actual specs. one website give 105db 24ohm, another one 105db 48ohm so it's hard to know. still that should be between 113 and 115db(into 48ohm, voltage would be the limit first). so you can expect about the same loudness or slightly less with the oppo(10db difference feels like twice as loud). if I had an impedance curve for the mdr1r I could be sure of this but I couldn't find one. so it's only about right.
my answer to you is , yes it will work, yes it should be loud enough, but yes it would deserve a good little amp to get the best sound possible because having to use the DAP almost at max volume isn't an ideal situation. I hope that gives you a clear idea.
The pm-3 has the same sensitivity as the pm-1. "Sensitivity 102 dB in 1 mW" 26 ohm. I'm listening right now with the pm-1's out of the A17 at a 20 level on the volume control and it's plenty loud and the sq is very good (96/24 album) At any setting below 19 the sound gets a little thin though. If the pm-3's are a little hotter on the sensitivity scale then it might be a good match.
thanks for the input!
cheers
