Sonic Defender
Yess, ladies and gentlemen, my FiiO L5 LOD broke down after 2 weeks!There is something wrong with the WM port end. My best bet is that the culprit is the strain on the cable that thick.![]()
My advice, buy the 30 cm long reasonably thick alternative on eBay instead.
Yep, or if you aren't actually bypassing the DAC in your Sony via the L5 and just bypassing the amp you can also get a longer analogue to analogue cable and go from the headphone out to the amps input. I really can't hear if the L5 route sounds better, but the headphone out from the Sony is louder so that is a plus. If you are passing through to a DAC that is able to take such a low voltage output that is different, but not many portable DACs take such a low output unless I'm mistaken. The Oppo HA 2 is reputed to have been tested with the A17 and it can accept such a low voltage at it's USB.
