audioxxx
- Sep 1, 2013
From my observations the line out is cleaner output, and offers better sound quality than the headphone output, when run into an amplifier.
I don;t understand how someone could think the amplified out is going to be better in a low level situation than the low level output? You are double amping with the amp'ed out, that's why they make the low level out adapter....
I don't think the double-amping is that clear-cut in this case. Sony uses the S-Master chipset, so no specific DAC chip. Maybe someone with better understanding of A10's design can help, but where does the DAC end and where does the amp begin? That always puzzled me.
After all, the EQ shouldn't work with the line out, but it does!
S-Master is just an invented word for software processing from Sony, nothing more than marketing. There is nothing ambiguous about where the DAC ends and where the analog stage begins if you take a close look at the chip deep into its topology. Of course, Sony isn't going to reveal its trade secret for us any time soon. The EQ works on line-out because it applies in the digital domain directly to the data stream before it reaches the DAC. Like any kind of software manipulate, it degrades the SQ in exchange of user tweakability - nothing ambiguous about that either. In the case of A10 series, I do think the software EQ has done more damage to the overall SQ than double amping. One of the clear evidence is the noticeable increase of hiss once you activate the EQ.
p/s: I'll try to measure line-out vs. headphone-out, plus EQ on/off when I have the time.
I see. A follow up question: Why is walkmans' lineout level that low? What is the difference (as far as internal design goes) between X1 and A17 to cause that?
There is no universally recognized standard of line-out voltage. However, for a good while most (or maybe just some of the major) chip maker and audio gear manufacturers agree that 2Vrms is a good voltage to use on desktop / main powered audio gears. However, due to the limitation of battery voltage, portable gears can't generate that high a line-out voltage (*as a rule, the analog output voltage can never be higher than the power supply voltage). To generate higher voltage, you need to include an extra step-up circuit to pump the battery voltage up first, which means you will get shorter battery life (and that's the case of X1). So those DAP maker that wants to keep their battery life as long as possible will do the opposite, by lower the voltage as low as they can get away from (and that's the case of Walkman in general).
There is no free lunch, so to speak. You pump up the voltage and you can get better SQ but lower battery life, or you lower the voltage for longer battery life but lesser SQ. It all depends on what your priority is.
Trying out the dsxee function on MP3. makes everything clearly sound worse. I don't understand the point of it.
