castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
The buttons feel solid, HOLD Switch is pretty tight, still get confused and try to use it as a fiio x3, ofteni do long-press with the Option menu and I end turning it off LOL, or when connected to the computer i try , to eject it by pressing the back/Home button haha like it was the fiio x3![]()
The buttons require a solid yet light pressing, not like my ex-NWZ-A818 whose buttins were pretty tight to press and noisy
the hold and volume buttons are just plastic pieces entrapped into the casing they have no reason to ever break, they don't get bent of forced when used. and the activation on the board is done the same way it was on many walkmans before( kind of small metal bubbles that pops back when released). it's a system that has been tested over the years.
and the jack isn't soldered to the board, it's also encased and glued to some slimy thing that allow for minimal movements. the only way to break it is by forcing enough to break the casing ^_^. and that stuff was already on a few previous walkmans(same jack system on my e585). so all in all protect the screen and you should be good for a good time.
