\Quote:
I wonder where pinkbecca saw that as well as i can't find anything listing any noise cancelling option on the USA Sony specs page for the NWZ-A17 which i'm sure features the exact same specs as the A15 and A16
there have been some Sony Walkman's that offer a noise cancelling feature (for example the e570 series and the F800 series) though only available when using the included earbuds or another specified Sony NC iem plus its set to off by default so you have to turn it on (though in the case of my F807 i have to admit it works pretty well, although personally i never use it)
http://store.sony.com/64-gb-hi-res-walkman-digital-music-player-zid27-NWZA17SLV/cat-27-catid-All-MP3-Players
Product Specifications
Audio
- Audio Modes : ClearAudio+/DSEE HX/5-band EQ/VPT/Dynamic Normalizer/DPC
- Station Preset(s) : Up to 30
- Audio Power Output : 10 + 10 mW
- Tuner : FM Tuner
- Tuner Frequency Range : 87.5 - 108.0 mHz
- Frequency Response : 20 to 40,000 Hz (when playing data file, single signal measurement)
- Audio Format(s) Supported :
MP3: 32-320 kbps (incl. VBR) at 32, 44.1, and 48 kHz
WMA: 32-192 kbps (incl. VBR) at 44.1 kHz
FLAC: at 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96, 176.4, and 192 kHz
L-PCM: at 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96, 176.4, and 192 kHz
AAC: 16-320 kbps (incl. VBR) at 11.025, 12, 16, 22.05, 24, 32, 44.1, and 48 kHz
HE-AAC: 32-144 kbps at 11.025, 12, 16, 22.05, 24, 32, 44.1, and 48 kHz
ALAC: 16-24 bit at 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96, 176.4, and 192 kHz
AIFF: 16-24 bit at 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96, 176.4, and 192 kHz
Audio Features
- Play Mode : Normal / Repeat / Shuffle / Shuffle & Repeat / Repeat 1 Song / SensMeTM channels
Bluetooth Feature & Device Bluetooth Audio
- Audio Codec : SBC, aptX codecs
- Color : Silver
Display
- Display Technology : TFT display with white-LED backlight
- Screen Size : 2.2 inch (5.6 cm) QVGA (320x240 pixels) 262,144 colors
General
- Backlit Color : White
- Music Storage Capacity (Approx) : 64 GB (expandable via optional microSD to 192 GB)
Hardware
- Display : 2.2 in. QVGA TFT display (320 x 240 pixels) 262,144 colors
- System Requirements : IBM PC/AT compatible computer preinstalled with the following Windows operating systems1:
Windows® XP2 (Service Pack 3 or later)
Windows Vista® (Service Pack 2 or later)
Windows® 7 (Service Pack 1 or later)
Windows® 8
Mac OS X v10.6 or later
Not supported by OSs other than above.
1-Excluding OS Versions not supported by Microsoft.
2 - Excluding 64-bit OS versions.
CPU: 1 GHz processor (2.6 GHz recommended for video playback)
RAM: 1 GB or more (2 GB RAM required for Windows 8 64-bit)
Hard Disk Drive / Solid State Drive: 600 MB or more of available space
Internet Explorer 7 or later
Internet connection (for Gracenote® MusicID® service, podcast features, Store access, or online help).
We do not guarantee operation for all computers even if they meet the above System Requirements.
Not supported by the following environments
Personally constructed computers or operating systems
An environment that is an upgrade of the original manufacturer-installed operating system
Multi-boot environment
- Interface : Hi-Speed USB (USB 2.0 compliant)
Inputs and Outputs
- Digital Audio Input(s) : WM-Port (22 pin)
- USB Port(s) : High-speed USB 2.0 compliant
- Headphone Output : Stereo mini-jack
Memory
- User Memory Capacity (Approx.) : microSD (up to 2 GB) microSDHC (up to 32 GB) microSDXC (64 GB and more up to 128 GB)
- Memory Size : 64 GB
Power
- Power Type : Built-in Rechargeable Li-ion Battery (weight 20 g separately)
- Battery Life (Approx) :
MP3 @ 128 kbps = 50 Hrs. (Bluetooth OFF), 23 Hrs. (Bluetooth ON);
Linear PCM @ 1411 kbps = 51 Hrs. (Bluetooth OFF), 23 Hrs. (Bluetooth ON);
FLAC @ 96 kHz/24 bit = 40 Hrs. (Bluetooth OFF), 16 Hrs. (Bluetooth ON);
FLAC @ 192 kHz/24 bit = 30 Hrs. (Bluetooth OFF), 11 Hrs. (Bluetooth ON);
MPEG-4 @ 384 kbps = 14 Hrs. (Bluetooth OFF), 10 Hrs. (Bluetooth ON);
Radio = Approx. 22 Hrs.
- Battery Indicator : LED Battery Life Indicator (Green/Orange/Red)
- Battery Charging (Approx) : USB-based:
4 Hrs (full charge)
- Battery Capacity : 960 mA/h
- Output Power : 10 + 10 mW
- Recharging Time : Approx. 4 hours
Video
- Video Format(s) Supported :
AVCHD: 10 Mbps bitrate, 30 fps frame rate, 720 x 480 max
MPEG4: 6 Mbps bitrate, 30 fps frame rate, 720 x 480 max
WMV9: 6 Mbps bitrate, 30 fps frame rate, 720 x 480 max
Video Features
- JPEG Playback : JPG: Max image size 4,096 x 4,096 pixels
Weights and Measurements
- Dimensions (Approx.) : 44.4 x 109.1 x 9.1 mm (1-3/4 X 4-3/8 x 3/8 in)
- Weight (Approx.) : 66 g (2.4 oz)
Wireless Connectivity
- Frequency Band : Bluetooth spec 2.1 + EDR 2.4 GHz band (2.4000 GHz-2.4835 GHz)
- Modulation Method : FHSS
- Maximum Range : Line of sight approx.30 ft (10 m)
