Hi PCheung, BTW how do you access to this load preset EQ page in WM1A? Thanks.
Ok, here are the step to save and load EQ on WM-1Z/A
should be the same on ZX300
1. First, go to the EQ setting and click the tool box on the right bottom corner
2. Tap the "Saved Sound Settings"
3. Here is the page you can save and load custom EQ setting
three slots "Saved sound settings 1 ~ 3" available
Let's say I tuned the EQ and want to save it for later use
Click the "Save Current Settings"
4. tap slot "Saved sound settings 1"
5. Pop-up warns this will overwrite the setting in slot 1, press "OK" to overwrite
6. Later you want to load the EQ 1
Than tap "Saved sound settings 1"
Pop-up warns this will load the EQ setting in slot 1
Press "OK" to load EQ
