MrWalkman
I just finished installing the new firmware, but not only did all my settings (including playback hours) completely reset, the playback hours in particular seem to reset back to nothing every time I restart the player. Is this normal? Did I do something wrong?
https://www.nwmods.ml/p/faq.html#walkman_one
When installing the firmware, the settings are backed up internally, and then you'll see 0 hours and all. When (if) you'll decide to go back to the stock firmware, the backed up settings will be restored, so the player will be as it was before installing the firmware.
This is because transferring over the settings to be used with the WM1A/Z-based Walkman One firmware may result in errors popping up and other buggy things. It is possible that it will work fine, but I don't own a ZX300 and I can't test that.
