I did with A30 and its the same os and zx300 was already reported to work with it. Also I am not a mac user and this worked perfectly easy on windowsUsing a MacBook, none of the files functioned. Did you make the manipulation yourself with a ZX300? Did it work?
Sony NW-ZX300
kms108
- Jan 27, 2012
Does this work on a 64bit windows 10 pc.
yesDoes this work on a 64bit windows 10 pc.
Mathieulh
YesDoes this work on a 64bit windows 10 pc.
PCheung
- Nov 25, 2016
I know what you mean, I can find the setting to save the EQ presets, but just nowhere to find a place can load these presets back.
Could you show me where you can load the EQ presets in WM1A/1Z? Thanks
Just tap "EQ 1" will load the saved setting in EQ 1
Ang Probinsyano
- May 1, 2017
Has anyone tried aune m1s? How does it compare to zx300 sq wise?
goody
- Apr 2, 2009
Only works on windows.can you let me know if you managed to change your Japanese zx300 to English menu .
One user already reported that it works.Only works on windows.can you let me know if you managed to change your Japanese zx300 to English menu .
- Oct 14, 2013
I meant to ask if the zx300 ability to be used as external usb DAC, could it be related to firmware only ? Or is it really hardware
Hi PCheung, thanks for your info, I will check this screenshot again whether it exists on the ZX300.
kms108
- Jan 27, 2012
I believe it's Mathieulh who has done this.Only works on windows.can you let me know if you managed to change your Japanese zx300 to English menu .
gobb
- Feb 27, 2017
The player is now at amazon.uk for 473£, but dispatch in 1-2 months?
OMG. They've discounted even before release in the UK!The player is now at amazon.uk for 473£, but dispatch in 1-2 months?
psikey
- Jul 15, 2008
Just seen & ordered. Bet its a short term drop as was listing at £600. If I import from Japan it was working out at £550. From what I've read I can recode to another region to remove EU volume cap? I'm not in a rush for delivery & I bet 1-2 months is just a cautionary date. My order is showing delivery: 2 Nov. 2017 - 1 Dec. 2017
Fortunately for me, I actually prefer silver over the black on. Might still order a case from Japan.
Now need to decide on B&W PX Headphones or the Sony WH-1000XM2B. Any advise on which?? I fancy some Bluetooth Aptx HD headphones will still use my SE846's balanced.
Any confirmation ZX300 can be used as DAC for a smart phone (not just PC).
goody
- Apr 2, 2009
i am so tempted do i need it i have the ZX100 bigger battery life bigger storage arghhh..But the ZX300 has more power and will probably sound better
Total: 13 (members: 0, guests: 13)
