One of my gripes with the ZX300 was lack of a convenient way to make playlists.
Wish, it had a function to select multiple files (as opposed to single select and wait a few seconds for it to add it to an editable playlist on the device)
Anyways, after months of trial and error, finally found an easy way to make playlists. (You will need a PC and a software called Potplayer)
1. Connect NW-ZX300 to the PC and turn on USB storage
2. Open Potplayer
3. Open Playlist Window in Potplayer
4. Add the song files
(browse to NWZX300 local storage (or external storage as desired)
Note: You can either select local or external storage. Can't mix
5. Save Playlist
(Potplayer Dropdown menu [top left corner] or Right click on player)
>Select Playback
>Playlist
>Playlist
>Save playlist as
>Browse to NWZX300 local storage (or external storage, if you added the files from it)
>MUSIC
>Type a file name of your choice
>Save as type: Winamp playlist -m3u (*.m3u; *.m3u8)
>Save
Et Voila! Turn off USB function on the player. Let the player create the database, browse to Playlists on the Home screen and you should find the playlist that you made.
Enjoy!
P.S - Since the playlist that works on the device is saved as a Winamp file, I guess it could also be done on a Winamp player. I haven't tried it though.
2. Open Potplayer
5. Save Playlist
>Select Playback
>Playlist
>Playlist
>Save playlist as
>MUSIC
>Save
Enjoy!
